Trim command through VBA
Sundar
Hi all,
I need to use trim and boundary command in VBA..But the entities should be passed from code to the command. (i.e) selection of entities for trimming and the portion to be trimmed off should be sent from code to the sendcommand..How to pass it in sendcommand.any suggestions?
I can use sendcommand method for passing trim command..but how to pass the objects say entities from a selection set to sendcommand method and another entity which is to be trimmed off..
I'm no expert on VBA, but this syntax was easily found in a quick Google search:
** Untested **
ThisDrawing.SendCommand "_trim (handent " & Chr(34) & "10a" & Chr(34) &
") (handent " & Chr(34) & "10b" & Chr(34) & ") (list (handent " & Chr(34) &
"10b" & Chr(34) & ") '(" & pt(0) & " " & pt(1) & " " & pt(2) & ")) "
