notview Posted March 20, 2013 Posted March 20, 2013 I'm copying objects with text specify the base point and that base point will be used as second point of paste to Polyline Vertex. Having a 500 polyline vertex, it takes 500 times paste. Instead, anybody could help making lisp routine by select the polyline objects the copied objects (e.g.: circle, polygon, polyline, text, ellipse) paste at once on the polyline vertexes. Thank you! Quote
Tharwat Posted March 20, 2013 Posted March 20, 2013 Can you upload a sample drawing showing before and after of the routine ? Quote
Tharwat Posted March 20, 2013 Posted March 20, 2013 Try this quick codes ... (defun c:Test (/ *error* ss s p i e cm) (defun *error* (x) (if cm (setvar 'cmdecho cm) ) (princ "\n*Cancel*") ) (if (and (setq ss (ssget "_X" '((0 . "LWPOLYLINE")))) (setq s (ssget "_:L")) (setq p (getpoint "\n Specify base point :")) ) (progn (setq cm (getvar 'cmdecho)) (setvar 'cmdecho 0) (command "_._copybase" "_non" p s "") (repeat (setq i (sslength ss)) (setq e (entget (ssname ss (setq i (1- i))))) (foreach pt e (if (eq (car pt) 10) (command "_.pasteclip" (cdr pt)) ) ) ) (setvar 'cmdecho cm) ) ) (princ) ) Quote
notview Posted March 20, 2013 Author Posted March 20, 2013 Something wrong.. after I select the base point, all objects having vertex automatically paste by the objects I copied, without selecting first the polyline where I supposed to paste the Objects copied. Quote
Tharwat Posted March 20, 2013 Posted March 20, 2013 Something wrong.. after I select the base point, all objects having vertex automatically paste by the objects I copied, without selecting first the polyline where I supposed to paste the Objects copied. If you want just to select specific polylines , just remove the "_X" from the code as shown in the following code . (setq ss (ssget [color=blue][b]"_X"[/b][/color] '((0 . "LWPOLYLINE")))) Quote
troggarf Posted March 20, 2013 Posted March 20, 2013 Found at the swamp by Alan JT http://www.theswamp.org/index.php?topic=35033.msg402543#msg402543 (defun c:CTV (/ foo ss lst pt) ;; Copy object(s) to vertices of select curves (Arc, Line, *Polyline, Spline) ;; Alan J. Thompson, 09.24.10 (defun foo (p) (if (vl-consp p) (or (vl-member-if (function (lambda (a) (equal (list (car a) (cadr a)) (list (car p) (cadr p))))) plst ) ((lambda (pnt) (foreach x lst (vla-move (vla-copy x) pt pnt)) (setq pLst (cons p pLst))) (vlax-3d-point p) ) ) ) ) (if (and (princ "\nSelect object(s) to copy: ") (setq lst ((lambda (i / ss e l) (if (setq ss (ssget "_:L")) (while (setq e (ssname ss (setq i (1+ i)))) (setq l (cons (vlax-ename->vla-object e) l)) ) ) ) -1 ) ) (setq pt ((lambda (p) (cond (p (vlax-3d-point (trans p 1 0))))) (getpoint "\nSpecify base point: ") ) ) (princ "\nSelect curves to copy object(s) along: ") (setq ss (ssget '((0 . "ARC,LINE,*POLYLINE,SPLINE")))) ) ((lambda (i / e eLst p pLst) (while (setq e (ssname ss (setq i (1+ i)))) (cond ((vl-position (cdr (assoc 0 (setq eLst (entget e)))) '("ARC" "LINE" "SPLINE")) (mapcar (function foo) (list (vlax-curve-getStartPoint e) (vlax-curve-getEndPoint e))) ) ((vl-position (cdr (assoc 0 eLst)) '("LWPOLYLINE" "POLYLINE")) (repeat (setq p (1+ (fix (vlax-curve-getEndParam e)))) (foo (vlax-curve-getPointAtParam e (setq p (1- p)))) ) ) ) ) ) -1 ) ) (princ) ) Quote
notview Posted March 20, 2013 Author Posted March 20, 2013 I try to removed "_X" but still not working. I try lisp given by troggarf, it's working good!! Thank you Tharwat and troggarf!!:)and also to Alan J. Thompson! Quote
Tharwat Posted March 21, 2013 Posted March 21, 2013 The codes work here , and I think it did not work for you due to the command copybase and pasteclip and my routine is very simple and nothings special . Quote
Enoc2013 Posted May 21, 2013 Posted May 21, 2013 DOES IT WORK ON AUTOCAD 2013?? I am not at all familiar with the codes you all discuseed Iam sorry Quote
