hi!
until now we used to label rooms in floor plans with blocks containing attributes. We manually typed in the area of drawn polylines (outline of rooms). only recently we found the very comfortable command "field" (object, polyline). is there a possiblity to insert the field command in the block that references a polyline outside the block??
i hope i got this straigt...
thanx
