Hey All,
I have lost all my objects in paperspace,
The layers for the objects are stille there, my viewport is there and working just can't see the border.
this problem is keeping comming back.
Working Autocad 2010 on windows xp.
Hope for some
08-34-5-2-302_01.1-__Out.dwg
Maybe if you looked at the attached file you would not have said that.
The viewport can be selected using Ctrl+A and filtered out using QSelect. The grips for any of these objects do not show up. I changed the properties of the viewport and still could not get it to display. I erased everything in paperspace and drew another viewport and that displays normally. I don't think I've ever seen this before.
What good is a viewport that can be selected but not displayed?
"I have lost all my objects in paperspace..."
What other objects did you find in the layout besides the viewport? Did you find the border?
Remark
If i do a select all, a total of 255 objects are selected.
spline (77)
line (58)
Polyline (23)
Block reference (3)
The border are just lines no block (i used undynamic before putting the file here)
this has happend a few times the last weeks.
Mvg John
John:
Exactly what did you lose that was in your paper space layout?
You didn't lose anything in model space right?
By the way, the vast majority of your objects have a negative X and negative Y coordinate. Why is that?
What he lost was the ability to see and select.
I took him to mean he actually lost objects like a title block, border, notes, etc. because he does say "I have lost all my objects..." in his initial post. I guess I was wrong.
Remark,
yes i lost title border, company logo (bmp) ... viewport..
i can't see them, i can't select them ...
everything on paperspace looks like it is gone, but "select all" shows different.
no problem in modelspace.
it is just that it's not the first time that this happens, and i can't find anything on the net about it.
Greetz John
There are references not found on the posted version.
Thank you for the additional information.
