Hello All,
I have a situation where I'm adding some text and want to identify the part with a part#. For example Item 1, I want to add a circle to the number one for it to stand out on my text notes.
The same goes for each line item I have for my text note. For example, if I have 5 lines of text notes, I want to be able to put for example a triangle around 1 thru 5 line items.
1.
2.
3.
4.
5.
I've attached screen shot to help to see what I'm looking to do. By the way used multiline text for my drawing notes.
Thanks in advance
KenJG
check True type fonts windings may be able to get fonts with number in Triangle or circle problem is when you exceed 9
Hello BIGAL ,
Thank you for your reply and suggestions. Have a Great Day & Weekend. I'm sure I'll be back with more questions.
Best Regards
KenJG
