Viu Posted March 24, 2013 Share Posted March 24, 2013 [ATTACH=CONFIG]41008[/ATTACH] Pictured is a part I'm trying to make out of sheet metal with a thickness of 0.07" However I'm not sure how to do this from a sketch viewing the part from a top or bottom down view, and I cannot draw the part unfolded, and fold it. Any help would be appreciated. [ATTACH]41009[/ATTACH] Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 24, 2013 Share Posted March 24, 2013 Sketch1 is not dimensioned. Read this http://home.pct.edu/~jmather/SkillsUSA%20University.pdf Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 24, 2013 Share Posted March 24, 2013 Pictured is a part I'm trying to make out of sheet metal with a thickness of 0.07" Dimensioning shows that your part is not .07" thick. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 24, 2013 Share Posted March 24, 2013 Your Sheet Metal Style is not set to .07" Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 24, 2013 Share Posted March 24, 2013 Sheet metal is bent to fold - you are missing bends. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 24, 2013 Share Posted March 24, 2013 (edited) You are doing too much work and using wrong tool (Extrude), only need single line profile and Inventor will add the bends for you. (forget this statement for now, it will be easier for you to see where you are going wrong if you dimension as double line profile for now.) When done correctly you will use the Contoured Flange tool and maybe the Rip tool, but first you need to get logical dimensions on this thing as the logic doesn't make sense. (that is why we dimension geometry) Edited March 24, 2013 by JD Mather Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 25, 2013 Share Posted March 25, 2013 How are you coming along on dimensioning? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 26, 2013 Share Posted March 26, 2013 It's been a couple of days now. Why did you ask question? Did you figure out how to dimension a sketch? Quote Link to comment Share on other sites More sharing options...
