Squirrel Cottage Posted March 25, 2013 Posted March 25, 2013 Hi Team I trust you are all well and in good spirits. This is what I would call an usual request, I am in the process of sorting out some wood engraving and acid etching of some brass plaques. I would like to know if it is possible to produce a cad drawing from a vector image and if so how ? This is one of the two images I would like to turn into a cad drawing. Worcester regiment [lion] last.pdf Quote
Rewind23 Posted March 26, 2013 Posted March 26, 2013 @Bespoke - I haven't tried this. But I saw a video which describes on How to convert PDF to AutoCAD file. Definitely scaling will play a big role on this one. There are other 3rd party applications to convert PDF/Vector Image to AutoCAD but with price though you may try it at your own responsibility (I haven't tried it). Maybe other fellow member has a better idea regarding your question.Regards Check this link: Quote
SLW210 Posted March 26, 2013 Posted March 26, 2013 How would this do for you? Worcester Regiment.dwg Quote
Squirrel Cottage Posted March 26, 2013 Author Posted March 26, 2013 How would this do for you? Fantastic. Could I trouble you to do the same magic to this cap badge ? Worcester regiment [stag] last r.pdf Quote
SLW210 Posted March 27, 2013 Posted March 27, 2013 The last one is a raster not a vector. Hopefully you find this conversion good enough. Worcester Regiment Stag.dwg Quote
Squirrel Cottage Posted March 27, 2013 Author Posted March 27, 2013 The last one is a raster not a vector. Hopefully you find this conversion good enough. Thank you What's the difference between a raster and avector ? Quote
