Siberian Posted March 26, 2013 Posted March 26, 2013 In the dimension style dialog I can set the color of different elements. One of them is ByBlock - which I never understood. What block does this refer to? Can someone explain it? Thanks Quote
MSasu Posted March 26, 2013 Posted March 26, 2013 Is about block entities - check the BLOCK command. The said ByBlock is a logical color - that it, the entity will assume the color of its container (the block). Quote
Tiger Posted March 26, 2013 Posted March 26, 2013 Is about block entities - check the BLOCK command. The said ByBlock is a logical color - that it, the entity will assume the color of its container (the block). It is only logical. Quote
Siberian Posted March 26, 2013 Author Posted March 26, 2013 ...the entity will assume the color of its container. But if I draw a dimension line (set to ByBlock) on whatever layer - what's its "container"? Quote
MSasu Posted March 26, 2013 Posted March 26, 2013 The ByBlock color (or linetype, for that matter) have meaning only for items that were inside block definitions. For more information on how to create and us a block, please check this tutorial. Quote
halfcracked Posted March 26, 2013 Posted March 26, 2013 ByBlock as it relates to dimensions means it will take the value of the dimension rather than the individual components. It treats the whole dimension as a block containing text, dimension line, extension line, arrow, etc. ByBlock allows you to say, change the color of a dimension without having to edit styles. Quote
neophoible Posted March 26, 2013 Posted March 26, 2013 ByBlock as it relates to dimensions means it will take the value of the dimension rather than the individual components. It treats the whole dimension as a block containing text, dimension line, extension line, arrow, etc. ByBlock allows you to say, change the color of a dimension without having to edit styles. Yeah, that's what I was going to say, but you said it so much better! Quote
