rocasan Posted March 31, 2013 Posted March 31, 2013 AutoCad 2011 I am unable to access the program. I started using Version 2008, 2009, 2010, 2010 and now 2011. This is the first time I have problems accessing the program. I get not messages. Please advise. Thank you. Quote
ReMark Posted March 31, 2013 Posted March 31, 2013 Did you create a Restore point before installing the program? So, what exactly does happen when you try to start AutoCAD 2011? Quote
rocasan Posted April 1, 2013 Author Posted April 1, 2013 I do not have a restore point. It is disable. Nothing happens when I click AutoCad Quote
edwinprakoso Posted April 1, 2013 Posted April 1, 2013 What is your operating system? Do you see AutoCAD launched in task manager? Quote
ReMark Posted April 1, 2013 Posted April 1, 2013 How does one go about disabling the ability to create a restore point in Windows? I wasn't aware this could be done. We create restore points as a form of insurance in case something goes wrong with an installation or we have no intention of keeping a new program much beyond testing to see if we like it. Did you encounter any problems during the installation process? Do you have admin rights to your computer? What version of Windows are you running? Vista? XP? Other? Did you disable the UAC before going ahead and installing AutoCAD? We need more information otherwise this is going to take way longer than it has to. Is your system even up to the specifications required to run the program in the first place? Example: Do you have enough RAM? Or, does your graphics card or chip meet the minimum requirements? Did you download the correct version of the program (i.e. - 32-bit vs. 64-bit)? Quote
