So I have this code that probably came from one of the users here and I wonder if it can be modified to set the layer filter current as part of the routine? If yes please modify or give me a hint.
(defun c:XREFNOT ( / xdict dict xrecname )
(vl-load-com)
   (setq xdict
       (vlax-vla-object->ename
           (vla-getextensiondictionary
               (vla-get-layers
                   (vla-get-activedocument (vlax-get-acad-object))
   (setq dict
       (if (setq dict (dictsearch xdict "ACAD_LAYERFILTERS"))
           (cdr (assoc -1 dict))
           (dictadd xdict "ACAD_LAYERFILTERS"
               (entmakex
                       (0 . "dictionary")
                       (100 . "AcDbDictionary")
                       (280 . 0)
                       (281 . 1)
   (princ
       (if (dictsearch dict (setq xrecname "No_Xref_Layers"))
           (strcat
               "Layer filter named <"
               xrecname
               "> already exists."
           (if
               (dictadd dict xrecname
                   (entmakex
                       (append
                               (0 . "xrecord")
                               (100 . "AcDbXrecord")
                               (280 . 1)
                           (list (cons 1 xrecname))
                               (1 . "~*|*")
                               (1 . "*")
                               (1 . "*")
                               (70 . 0)
                               (1 . "*")
                               (1 . "*")
                               (-3
                                   (   "ACAD"
                                       (1000 . "( NAME== \"~*|*\" )")
               (strcat
                   "Created layer filter named <"
                   xrecname
               "Doh! Something horrible happened. "
Thanks,
rkent
Edited by SLW210
Code Tags~Not Quote Tags!!
Just use the undocumented "Filter" (or "_FI") option for the -LAYER Command:
(command "._-layer" "filter" "set" "[color="red"]YourCaseSensitiveLayerFilterName[/color]" "")
Great, gotta love those undocumented options.
Thanks.
Thanks.
Happy to help, Rkent. :beer:
FWIW - You might also find this one to be of use:
(command "._vplayer" "reMoveoverrides")
BlackBox - is the code I posted yours? I don't remember where it came from and I try to add the source even if it isn't put there by the author.
Thanks for vplayer option.
Not at all; I do recall having interest in this topic, but never did anything about it (par for the course, unfortunately, given my availability).
I know that I had come across a post by Lee on the topic in passing, but couldn't tell you if that code is his either... I do not know him to be that big of a fan of the Simpsons though... Perhaps Kruuger? :lol:
Anytime.
Thanks for the confirmation, Lee.
