I found a lisp routine to make a 2d railroad track but it has some errors in it and I know nothing about writing lisp routines and so I cannot figure out where the errors are or how to fix them. I am using Civil3d 2012. Thanks for any help on this.
Here is the code:
;Create a railroad line from a defined centerline drawn as a polyline
(defun C:rrtrax ( / curlyr rr-cl rrlyr oldosnap rt lt e ename etype nent
tent osdone entstart cntr bulge rtoff
ltoff startpt TblLst bss blname lyrcount)
(defun myerror (s) ; If an error (such as ESC or invalid
selection) occurs
; while this command is active...
(if (/= s "Function cancelled")
(princ (strcat "\nError: " s))
(setvar "osmode" oldosnap)
(command "_layer" "s" curlyr "") ; Restore saved modes
(setq *error* olderr) ; Restore old *error* handler
(command "undo" "begin" )
(setq olderr *error*
*error* myerror)
(setq oldosnap (getvar "osmode"))
(if (< oldosnap 16384)(setvar "osmode" (+ 16384 oldosnap)))
(setq curlyr (getvar "clayer"))
(setq rrlyr "1-RR-TRACK")
(setq rrcl "rr-cl")
(if (= (tblsearch "layer" rrlyr) nil)
(command "_layer" "n" rrlyr "c" "12" rrlyr "s" rrlyr "")
(command "_layer" "T" rrlyr "on" rrlyr "s" rrlyr "")
(if (= (tblsearch "layer" rrcl) nil)
(command "_layer" "n" rrcl "")
(command "_layer" "T" rrcl "on" rrcl "")
(defun osline ()
(setq rt (polar entstart (+ (angle entstart entend) (/ pi 2)) 1.0)
lt (polar entstart (- (angle entstart entend) (/ pi 2)) 1.0)
(doos rt lt)
) ;end osline
(defun osarc ()
(setq rt (polar entstart (angle entstart cntr) 1.0)
lt (polar entstart (angle cntr entstart) 1.0)
(doos rt lt)
) ;end osarc
(defun dopoly ()
(setq osdone nil
ename (entnext ename)
tent (entget ename)
nent (entget (entnext ename))
(while (/= "SEQEND" (cdr (assoc 0 nent)))
(setq entstart (cdr (assoc 10 tent))
entend (cdr (assoc 10 nent))
bulge (cdr (assoc 42 tent))
(if (= bulge 0.0)
(drawline)
(drawarc)
(setq ename (entnext ename)
tent (entget ename)
);end dopoly
(defun drawline ()
(if (= osdone nil)
(osline)
(setq startpt entstart)
(defun drawarc ()
(if (= osdone nil)
(osarc)
(defun doos (rt lt)
(command "_offset" (/ rr_w 2) e rt "")
(command "_change" "l" "" "p" "la" rrlyr "")
(setq rtoff (entlast))
(command "_offset" (/ rr_w 2) e lt "")
(command "_change" "l" "" "P" "LA" rrlyr "")
(setq ltoff (entlast))
(setq osdone t)
) ;end doos
;Make block if needed
(defun makebl ()
(entmake '((0 . "BLOCK")
(2 . "rr-tie")
(8 . "1-RR-TRACK")
(70 . 0)
(10 0.333 3.354 0)
(entmake '((0 . "LWPOLYLINE")
(100 . "AcDbEntity")
(8 . "1-RR-TRACK")
(100 . "AcDbPolyline")
(90 . 4)
(10 0.00 0.00)
(10 0.666 0.00)
(10 0.666 6.708)
(10 0.00 6.708)
(70 . 129)
(entmake '((0 . "ENDBLK")))
(defun GetFilterTable (Tbl Nme / CurTbl)
(setq TblLst nil)
(while (setq CurTbl (tblnext Tbl (not CurTbl)))
(if (wcmatch (cdr (assoc 2 CurTbl)) Nme)
(setq TblLst (cons CurTbl TblLst))
(reverse TblLst)
(defun insblock ()
(setq bss (ssget "_X" '((2 . "rr-tie"))))
(ssadd rtoff bss)
(ssadd ltoff bss)
(if (= (GetFilterTable "BLOCK" "TRACKS-*") nil)
(setq blname "TRACKS-1")
(setq lyrcount (1+ (length TblLst)))
(setq blname (strcat "TRACKS-" (rtos lyrcount)))
);end if
(command "_-block" blname startpt bss "")
(command "_-insert" blname startpt 1 "" 0)
(if (= rr_w nil)(setq rr_w 4.708))
(princ (strcat "\nDraws U.S. Standard <" (rtos rr_w) "'> railroad
tracks."))
(setq e (entsel "\nPick a LWPolyline: "))
(while e
(setq ename (car e)
etype (cdr (assoc 0 (entget ename)))
(if (or (= etype "POLYLINE")(= etype "LWPOLYLINE"))
(if (= etype "LWPOLYLINE")
(command "_convertpoly" "h" e "")
(setq @poly T)
(dopoly)
(setq e2 e)
(setq e nil)
(setq e (entsel "\nYou must pick a POLYLINE - Try again"))
;Make Tie block if not exist
(if (= (tblsearch "block" "rr-tie") nil)
(makebl)
);end block if
(command "_measure" e2 "b" "rr-tie" "y" "3" )
(insblock)
(command "_change" e2 "" "P" "la" "rr-cl" "")
(command "_layer" "off" "rr-cl" "")
(setq bss (ssget "_x" '((2 . "rr-tie"))))
(if (= @poly T)
(command "convertpoly" "l" e2 "")
(command "undo" "end" )
What kinds of errors? Can you be more specific?
Some standard gauge dimensions look to be:
Rails:
  • 8' 4-1\2" between inner edge iof the rails
  • 2-3\4" wide at the head
  • 5-1\2" wide at the base
  • 6" high overall
Ties:
  • 9" wide x 7" high x 102" long
  • 19.5" on center
Are these the dimensions you use?
-David
well there is one extra right prens at the very end.
HTH
The dimensions work good for me. The main issues I am having with it : 1. When I load it using appload, it immediately is asking for input instead of waiting for me to invoke the command. 2. After I load it, other than when it auto starts the command, I can't use it without using appload again. 3. If I load it to my startup suite, it goes directly into the command as soon as I start a new drawing and again it won't work after that, unless I use appload. Thanks for your help on this.
Sounds like you need to look into the extra parenthesies as Steve suggested. -David
I deleted the last parenthesis as suggested, but that didn't make a difference in the errors.
Rails:
  • 8' 4-1\2" between inner edge of the rails
I hope that should read 4' 8½" otherwise there is a budding broad gauge :shock:
I'm sorry, but the routine is so poorly written, it would be a wouldn't be wise use of time to to try and decypher it. -David
How can many ways can you say dyslexic ! Good Catch ! -David
It is nice routine, I wish it worked better.
I believe I grabbed my copy off of Autodesk community.
You might see if you can find the Author and have them give it a look.
It figures. The one I finally find that does the tracks exactly like I want, has all these errors in it. Just my luck I guess. Thanks for trying to help guys.
Edited by gghg
Removed wrong quote
Yeah I agree it works really well if not for the errors.
Here's a brute force method with way too many (command ) references for me.
HTH -David
RRAIL.LSP
HTH -David
When I try to select objects, whether its a line or polyline, it says no objects found.
If anyone tries this and figures out how to fix it or if someone could write a lisp that does what this one does but without errors I would be very appreciative.
