Hello people,
I'ld like to make a cable list of components that are connected.
Autocad electrical does it fine. when drawing a line from an electrical component to another, it kinda makes a link with the attribute of the block, witch you can extract the data from and obtain a cable list.
Is it possible to make blocks interact the same way with a regular Autocad?
Maybe trough some lisp routine or something?
Any input would be helpfull ;)
regards,
SB
If is about blocks with attributes, please check the DATAEXTRACTION built-in command.
erm...
I might be mistaken, but i think you didn't get the question right...
I know all about dataextraction, that's not the problem.
What i'm trying is to make an object recognise another...
adentum:
Like you would have a block with an attribute and an anchor point, and when drawing a line to that anchor point, when extracting data, the result would be something like: FROM "some name" TO "some name"...
Some name would be the anchor point's attribute name, like the connectic of a switch f.e. (S1, connectic n° 13)...
Acad Electrical uses special codes as TAG name to do this. I'm looking for some lisp that would be the structure providing this function.
SB
Edited by Sittingbull
complete
