cad 2006 ; after using a new command (auto numbering) created by a auto lisp.fas
file The key board function of Ctrl+z is not work.but Ctrl+c or Ctrl+v is working.
U next Enter or click on Undo function also working. Only problem occur on Ctrl+Z.This error is happening all computers with cad 2006.
Unfortunately I do not have permission to attached this fas.file to you.
Already Control has set to All, and UNDOCTL = 29 (Readonly)
Does Ctrl+Z work in other programs?
Did you check to see if this has been redefined in your shortcuts?
Options>User Preferences>Windows Standard Behaviour>Windows Standard Accelerator Keys been checked?
1. Yes this function is correctly working in cad 2012 and zw cad trial version (same pc)
2. No it has not refined my shortcuts
3 Options>User Reference > Windows Stranded Behavior (Not available in cad 2006)
