fiddleback143 Posted April 4, 2013 Share Posted April 4, 2013 I'm trying to cut down on the number of visibility states for a block under development. Currently I have a rectangle, 4'x2', with other lines that I don't need to modify. What I want to do is to stretch the rect into a 4'x4' square and add 2 circles in the corner. I have no problem with the stretching part it's adding in the two circles that I don't even know where to start. This element will cut in half the visibility states that I need to make. Quote Link to comment Share on other sites More sharing options...
Mike_Taylor Posted April 4, 2013 Share Posted April 4, 2013 I wiould recommend using a STRETCH paramater with a lookup. This will essentially give you two drop downs, one for the circles and one for the stretch. The other pissibility would be a stretch parameter that the user can move to acheive the desired length (you can make a list of lengths here). I do not have access to CAD right now, so I cannot put an example up unfortunately. Quote Link to comment Share on other sites More sharing options...
