Trying to design a cap that covers 3 separate planes.
Hey guy's!!
I'm practicing my rusty Solidworks skills by modeling the Millennium Puzzle from yugioh. However I'm having a heck of a time trying to extrude the caps on the four corners of the puzzle:
I've just discovered that you can't extrude a 3D sketch and I need some advice. Any ideas?
Millennium Puzzle - Pyramid.SLDPRT
Looks like you need to add face draft or replace face on these to faces to get them coplanar with the sides of the pyramid.
Then do a circular pattern (you will need an axis) or create the same sketches on the other two sides and two more extrusions and fix it up as described above.
Then do a circular pattern to the other 3 corners.
  • 11 months later...
Your sketch didn't need to be a 3d sketch.
Do one sketch per face and extrude then pattern them like JD said...
3 sketches, 3 extrudes per corner...
