can somebody post some sample code or guidlines on how to position an attribute in a block constructed in VB.Net?
I am making a block comprising a triangle (pline - -6,0:6,0:0,10 & close) and an attribute, centre justified. I want the base point of the trianle to be in the middle of its base (done) and the attribute to be 0,3 but I can't seem to be able to position anywhere other than 0,0.
(I know I can draw the triangle 3mm lower but that wouldn't put the insert point where I want.)
Try this code, change to your suit
       <CommandMethod("Tri", CommandFlags.Modal Or CommandFlags.Redraw)> _
       Public Shared Sub CreateTriangleMark()
           ' Get the current document and database
           Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
           Dim db As Database = doc.Database
           Dim ed As Editor = doc.Editor
           Using tr As Transaction = db.TransactionManager.StartTransaction()
               Try
                   Dim bt As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForWrite), BlockTable)
                   ' get current text size for attribute or use hard coded one instead
                   Dim txtheight As Double = db.Textsize
                   ' block name
                   Dim blkName As String = "TRIANGLE"
                   ' check if exists
                   If bt.Has(blkName) Then
                       ed.WriteMessage(vbLf & "Block ""TRIANGLE"" already exist.")
                       ' if exists then exit
                       Return
                   End If
                   Dim btr As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                   Dim inspt As New Point3d(0, 0, 0) '' perrhaps use: New Point3d(0, 5, 0) not sure about
                   Dim newBtr As New BlockTableRecord()
                   bt.Add(newBtr)
                   ' change settings for you block to your suit:
                   newBtr.Name = blkName
                   newBtr.Origin = inspt
                   newBtr.BlockScaling = BlockScaling.Uniform
                   newBtr.Units = UnitsValue.Inches
                   newBtr.Explodable = False
                   tr.AddNewlyCreatedDBObject(newBtr, True)
                   Dim pline As Polyline = New Polyline(3)
                   pline.AddVertexAt(0, New Point2d(-6, 0), 0, 0, 0)
                   pline.AddVertexAt(1, New Point2d(6, 0), 0, 0, 0)
                   pline.AddVertexAt(2, New Point2d(0, 10), 0, 0, 0)
                   pline.Closed = True
                   pline.Layer = "0"
                   pline.LinetypeId = db.ContinuousLinetype
                   '' color by block
                   pline.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(ColorMethod.ByAci, 0)
                   '' lweight by block
                   pline.LineWeight = LineWeight.ByBlock
                   newBtr.AppendEntity(pline)
                   tr.AddNewlyCreatedDBObject(pline, True)
                   Dim attr As New AttributeDefinition()
                   attr.Layer = "0"
                   attr.LinetypeId = db.ContinuousLinetype
                   attr.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(ColorMethod.ByAci, 0)
                   ' color by block
                   attr.LineWeight = LineWeight.ByLineWeightDefault
                   attr.Tag = "DESCRIPTION"
                   attr.Prompt = "Description:"
                   attr.TextString = "blah"
                   attr.Preset = True
                   ' using current textstyle
                   'attr.TextStyle = db.Textstyle ''<--   A2009
                   attr.TextStyleId = db.Textstyle ''<--   A2010
                   attr.Height = txtheight
                   attr.Position = New Point3d(0, 5, 0)
                   '' apply alignment
                   attr.Justify = AttachmentPoint.MiddleCenter
                   attr.AlignmentPoint = attr.Position
                   attr.LockPositionInBlock = True
                   attr.AdjustAlignment(db)
                   newBtr.AppendEntity(attr)
                   tr.AddNewlyCreatedDBObject(attr, True)
                   tr.Commit()
                   ed.Regen()
               Catch ex As Autodesk.AutoCAD.Runtime.Exception
                   ed.WriteMessage(ex.Message + vbLf + ex.StackTrace)
               End Try
           End Using
       End Sub
Thanks Fixo, I'll give that a try (don't knowwhy I said try, you've never let me down) on Monday.
A couple of things to ask you
I am now on 2013. I notice you have commented the differences between 2009 & 2010. I assume I will see the correct format on the command line when I code it. Likewise the changes between metric & imperial will be obvious.
from memory I didn't do these statements
Is it that that adjusts the position of the attribute? Presumably these lines need repeating for each attribute being positioned.
And one question,
what does DirectCast do? I have not seen that command yet.
and another question that I know I asked (with your other user name) but have forgotten your answer. Where is Pietari, Venäjä?
my google search brings up St Petersburg, Russia - is that correct? If it is, I intend visiting in a few years time (2015!) and can I ask some "tourist" questions.
Edited by dbroada
"Chat" question added
additional to edit, I have found that you do live in St Petersburg.
I have a grand tour by train planned for a couple of years time so you may see a pm from me later asking about best time of year to visit Russia etc.
I just learned this the other week....
DirectCast-ing results in either a Typed Object (the Type you've just casted to), or an Exception.
Casting an object to a Type with the As operator results in either a valid, Typed Object, or Nothing (Null in C#).
Lastly, the Is operator can be used to qualify if an Object is the Typed Object being compared against, discards the resultant casted Object or Exception, and returns a bool (i.e., true / false).
fixo, thanks, that worked how I wanted.
BB, and thank you. Still not sure whatit all means just yet though. :D :rtfm:
this.Mode = Modes.Rant;
I just spent, what is I'm sure too long, writing a summary of what I described above, including code samples in VB and C#, only for CADTutor to inform me when I hit the 'Go Advanced' button that I needed to hit the back button... At which time everything was lost, and only this blank post remained. tickedoff.gif
Just wanted to let you know that I tried, and that I might give it another go, another time... once I cool off. *ticked off*
I thank you for your effort and know your frustrations. That has happened tp me several times in the past. A contributing factor towards my answers being of few words....
hopefully this will help you get to
this.Mode = Modes.Calm
:beer: :popcorn: :beer: :playing: :beer:
That happened to me also a couple of times. Now when I go from 'Quick Reply' to 'Go Advanced' I always copy all of my new post to the clipboard, just in case it gets lost when switching over. Perhaps David could incorporate a function to save a draft of a post, just so it does not "get lost".
