This is on ACAD2013
I'll try to keep this short and sweet. I set my helix around the shaft, looks good. I draw my thread shape, attempt to make my sweep, unable to sweep (overlap issue). :x I reduce the size of my shape, it sweeps. I cut my thread into the shaft and I noticed that my thread is spacing out as it moves down the shaft. Did I miss something?
ACAD13ThreadFailure.dwg
I had seen your guide there, but I ignored where your tool was directly on the helix. I did this because I had seen other tutorials where it was positioned off of the helix and it appeared to work for them. I placed my tool on the helix and it cut perfect. Thank you.
