Bladezy Posted April 8, 2013 Posted April 8, 2013 Hi guys, I'm having some issues with some code i'm writing. i'll start off by giving you a idea of what i'm trying to do first:- The engineering firm i work for would like to have a 'check box legend' for our drawings. for example, we would like to have check boxes that you can select, that intern, depicts what is shown in our legends and what is not. eg. if you want to show an electrical service line in your legend, all you have to do is tick the box and it automatically inserts it into the legend on that specific page. okay so i've started writing this code (see attached) when i implement it into ACAD i get 3 errors in this order. 1: error in dialog file 'C:\users\bladest\desktop\project\LEGEND.dcl' at end-of-file: premature end of file. 2: error in dialog file 'C:\users\bladest\desktop\project\LEGEND.dcl' at end-of-file: syntax error symbol "spacer_0" 3: the LEGEND.dcl file could not be loaded! any ideas guys? this one has got me stumped. the attached .dcl and .lsp files are what i'm using. Cheers guys! LEGEND.dcl LEGEND.LSP Quote
fixo Posted April 8, 2013 Posted April 8, 2013 LEGEND.dcl I removed all redundants from there, see if this is looking good enough Quote
Bladezy Posted April 8, 2013 Author Posted April 8, 2013 Hi Fixo, Thankyou for your quick response. i am still getting the same 3 errors. 1: error in dialog file 'C:\users\bladest\desktop\project\LEGEND.dcl' at end-of-file: premature end of file. 2: error in dialog file 'C:\users\bladest\desktop\project\LEGEND.dcl' at end-of-file: syntax error symbol "spacer_0" 3: the LEGEND.dcl file could not be loaded! i have tried moving the file locations to my support file location on my C:\ but still no good. what is my next option? Regards, Quote
fixo Posted April 8, 2013 Posted April 8, 2013 Sorry have not tested dcl with lisp, I will try it later After the quick glance this dialog loaded and works correct on my end I'm using A2010 btw, but the problem is with blocks, i could not use them See command line feedback Command: SPECIFY TOP LEFT CORNER OF LEGEND INSERTION POINT: "t0.dwg": Can't find file in search path: C:\Users\Олег\Programming\Lisp\AASNIPPETS\DCL\ (current directory) C:\Program Files\AutoCAD 2009\Support\ C:\Users\Олег\AppData\Roaming\Autodesk\AutoCAD 2009\R17.2\enu\support\ C:\Program Files\AutoCAD 2009\help\ C:\Program Files\AutoCAD 2009\Express\ C:\Program Files\AutoCAD 2009\support\color\ C:\Program Files\INCDEC\ C:\Program Files\AutoCAD 2009\Support\Progs\ C:\Program Files\AutoCAD 2009\Support\Progs\Tools\ C:\Program Files\AutoCAD 2009\Support\Progs\Icons\ C:\Users\Олег\Programming\FORUMS\Augi\WeldBlocks\ C:\Program Files\AutoCAD 2009\drv\ C:\program files\autocad 2009\drv\ C:\Program Files\AutoCAD 2009\ *Invalid* Another possible issue would be solved with saveing DCL in UTF-8 encoding, if you're working in Acad > 2010 release, create copy in UTF-8, then temporarilly move your current DCL from working folder and try lisp again with UTF-8 copy Quote
gS7 Posted April 8, 2013 Posted April 8, 2013 Found Error Check This Bladezy Missing ,Curly Bracket end of line Hint : 1: error in dialog file 'C:\users\bladest\desktop\project\LEGEND.dcl' at end-of-file: premature end of file. dcl_settings : default_dcl_settings { audit_level = 0; } LEGEND : dialog { label = "LEGEND CREATOR v1.0"; :column { :row { :text { key = "text1"; width = 30; label = "Make a selection"; } :row{ :button{ label = "Select All"; key = "selall"; fixed_width = false; } :button{ label = "Deselect All"; key = "selnone"; fixed_width = false; } } } spacer_0; :boxed_row{ label = " Sedimentation "; :column{ :toggle{ key = "t1"; label = "CatchDrain "; } :toggle{ key = "t2"; label = "Low Flow Bank "; } :toggle{ key = "t3"; label = "Traffic Manoeuvring"; } } :column{ :toggle{ key = "t4"; label = "OverFlow Path "; } :toggle{ key = "t5"; label = "Sediment Fence"; } :toggle{ key = "t6"; label = "Vehicle Shaker Grid"; } } :column{ :toggle{ key = "t7"; label = "Stabilised Site Access "; } :toggle{ key = "t8"; label = "Stockpile Location"; } :toggle{ key = "t9"; label = "Straw Bale Filter"; } } :column{ :toggle{ key = "t10"; label = "Geotextile Inlet Filter "; } :toggle{ key = "t11"; label = "Mesh && Gravel Inlet Filter"; } // :toggle{ // key = "t12"; // label = "Temp Rock Headwall"; // } // :toggle{ // key = "t13"; // label = "Proposed Rip Rap"; // } spacer_1; } :column{ fixed_height = true; :button{ label = "ON "; key = "selall1"; fixed_width = true; alignment = centered; } :button{ label = "OFF"; key = "selnone1"; fixed_width = true; alignment = centered; } } } :boxed_row{ label = " Roads && Drainage "; :column{ :toggle{ key = "t14"; label = "Limit of Work "; } :toggle{ key = "t15"; label = "Bdy Existing"; } :toggle{ key = "t16"; label = "Bdy Proposed"; } :toggle{ key = "t17"; label = "Ridge Line"; } :toggle{ key = "t18"; label = "Valley Line"; } :toggle{ key = "t19"; label = "Subsoil Proposed"; } :toggle{ key = "t20"; label = "Table Drain"; } :toggle{ key = "t21"; label = "Pits - Junction"; } } :column{ :toggle{ key = "t22"; label = "Pits - Surface inlet"; } :toggle{ key = "t23"; label = "Pits - Lintels"; } :toggle{ key = "t24"; label = "Pit Tag"; } //new toggles :toggle{ key = "t100"; label = "SW Pit Info"; } :toggle{ key = "t101"; label = "SEW Pit Info"; } // :toggle{ key = "t25"; label = "Grateddrain"; } :toggle{ key = "t26"; label = "SW Existing"; } :toggle{ key = "t27"; label = "SW Proposed"; } } :column{ :toggle{ key = "t28"; label = "Batter Existing"; } :toggle{ key = "t29"; label = "Batter Proposed"; } :toggle{ key = "t30"; label = "Contour Existing"; } :toggle{ key = "t31"; label = "Contour Proposed"; } :toggle{ key = "t32"; label = "Contour BE"; } :toggle{ key = "t33"; label = "Spot Level Proposed"; } :toggle{ key = "t34"; label = "Spot Level BE"; } } :column{ :toggle{ key = "t35"; label = "Kerb - K&&G"; } :toggle{ key = "t36"; label = "Kerb - KO"; } :toggle{ key = "t37"; label = "Kerb - IK"; } :toggle{ key = "t38"; label = "Kerb - BK"; } :toggle{ key = "t39"; label = "Kerb - RK"; } :toggle{ key = "t40"; label = "Dish Gutter - DG"; } spacer_1; } :column{ fixed_height = true; fixed_width = true; :button{ label = "ON "; key = "selall2"; fixed_width = true; alignment = centered; } :button{ label = "OFF"; key = "selnone2"; fixed_width = true; alignment = centered; } } } :boxed_row{ label = "Existing Services Proposed Services"; :column{ :toggle{ key = "t41"; label = "EXSRV Electrical "; } :toggle{ key = "t42"; label = "EXSRV Gas"; } :toggle{ key = "t43"; label = "EXSRV Sewer"; } :toggle{ key = "t44"; label = "EXSRV Telstra"; } :toggle{ key = "t45"; label = "EXSRV Water"; } } :column{ :toggle{ key = "t46"; label = "EXSRV Rising Main "; } :toggle{ key = "t47"; label = "EXSRV Opt-Fibre"; } :toggle{ key = "t48"; label = "EXSRV Optus"; } :toggle{ key = "t49"; label = "EXSRV ERM"; } :toggle{ key = "t50"; label = "EXSRV IRM"; } } :column{ :toggle{ key = "t51"; label = "SRV Electrical "; } :toggle{ key = "t52"; label = "SRV Gas"; } :toggle{ key = "t53"; label = "SRV Sewer"; } :toggle{ key = "t54"; label = "SRV Telstra"; } :toggle{ key = "t55"; label = "SRV Water"; } } :column{ :toggle{ key = "t56"; label = "SRV Rising Main "; } :toggle{ key = "t57"; label = "SRV Opt-Fibre"; } :toggle{ key = "t58"; label = "SRV Optus"; } :toggle{ key = "t59"; label = "SRV ERM"; } :toggle{ key = "t60"; label = "SRV IRM"; } } :column{ fixed_height = true; fixed_width = true; :button{ label = "ON"; key = "selall3"; fixed_width = true; alignment = centered; } :button{ label = "OFF"; key = "selnone3"; fixed_width = true; alignment = centered; } } } :row{ :boxed_row{ fixed_width = false; label = " Jointing "; :column{ :toggle{ key = "t61"; label = "Joint - CJ"; } :toggle{ key = "t62"; label = "Joint - DCJ"; } :toggle{ key = "t63"; label = "Joint - DEJ"; } :toggle{ key = "t64"; label = "Joint - DJ"; } spacer_1; spacer_1; } :column{ fixed_width = true; :toggle{ key = "t65"; label = "Joint - EJ "; } :toggle{ key = "t66"; label = "Joint - IJ"; } :toggle{ key = "t67"; label = "Joint - SC"; } :toggle{ key = "t68"; label = "Joint - TEJ"; } spacer_1; spacer_1; } :column{ fixed_height = true; fixed_width = true; :button{ label = "ON"; key = "selall4"; fixed_width = true; alignment = centered; } :button{ label = "OFF"; key = "selnone4"; fixed_width = true; alignment = centered; } } } :boxed_row{ label = " General "; :column{ :toggle{ key = "t69"; label = "Sheet Join Line"; } :toggle{ key = "t70"; label = ""; } :toggle{ key = "t71"; label = ""; } :toggle{ key = "t72"; label = ""; } :toggle{ key = "t73"; label = ""; } } :column{ } :column{ } } } spacer_1; :toggle{ key = "save"; label = "Save Settings"; } spacer_1; :image{ key = ""; width = 0; aspect_ratio = 1; color = 7; } ok_cancel_help; :column{ :paragraph{ :text{ key = "copyright"; label = ""; alignment = centered; } } } [color="red"] } spacer_0 ;}[/color] Quote
Bladezy Posted April 8, 2013 Author Posted April 8, 2013 awesome! thanks guys it is running smoothly now I will try with the blocks inserts and see if there are anymore issues. Regards, Quote
Lee Mac Posted April 8, 2013 Posted April 8, 2013 I'm having some issues with some code i'm writing. okay so i've started writing this code (see attached) Looks like the code has been taken from here. Quote
neophoible Posted April 8, 2013 Posted April 8, 2013 Looks like the code has been taken from here. Yes. It looks like the OP initially tried to use (bump) that thread to ask if he could ask a question of the author (here). Don't know why it wasn't cited here. Quote
