How can I open the global illumination in 3ds Max 2013 and what is its shortcut?
Thank you
How do you open it? :?
Open up your Render Setup window, go to the "Indirect Illumination" tab and scroll down to "Caustics and Global Illumination (GI)"
Put a check in the "Enable" box under "Global Illumination"
Are you using 2012 or 2013? You said 2012 in your thread title, but in your post, you said 2013.
