Hi all,
I'm a newbie to dynamic blocks, have only started working with them for the past couple of weeks now and I have encountered a problem!
I prefer using Visibility State to flip objects instead of actually using the Flip command! Simply because there are less grip points for the user when using this block. My problem is: when adjusting the physical properties of the block by using the dynamic features and then changing the visibility state (e.g. left to right), the block is no longer intact so all of the grip points will no longer alter the block accordingly.details-section_marker(both).dwg
I have attached the block just incase no one can understand my mess! Any help or suggestions would be greatly, greatly appreciated!!! Thanks in advance.
I think it has to do with what you have selected for the actions in each visibility state. When I first inserted your block into my drawing, it had all the visibility states visible.
If you are not liking the addition grips, you can always use a flip action, set the number of grips to 0, and use a lookup to set the flip. This leaves your visibility state open for other purposes as well.
