jiggly_jelloo Posted April 12, 2013 Posted April 12, 2013 For the past 2 days when I switch from one drawing to another, my layout tabs are not updating and stay the same as the previous drawings. I have to do a regen to get the proper tabs in place. All the layouts are there...it is just the tabs that are messed up. Once I click on one of the tabs they straighten themselves out as well, but on that first selection I never get the correct drawing that I want! There were some windows updates that installed around the time ACAD starting doing this so maybe one of those is causing this. Any suggestions? Quote
tonyj Posted April 12, 2013 Posted April 12, 2013 Not sure I know what you mean. When the layouts are correct, after you do a regen, or whatever it is you do, do you actually resave the drawing so that it will be that way the next time you open it? Quote
jiggly_jelloo Posted April 12, 2013 Author Posted April 12, 2013 Not sure I know what you mean. When the layouts are correct, after you do a regen, or whatever it is you do, do you actually resave the drawing so that it will be that way the next time you open it? I will try to explain a bit clearer. Say I have 2 drawings open A & B and I am working on drawing A. Now someone comes to me and asks to make a change in drawing B, so I switch to that drawing. Now drawing B appears on my screen but the layout tabs are still from drawing A. So say I select layout tab S1...it doesnot open layout S1 but whatever is in that layout tab position on Drawing B. Once I select a layout tab or do a regen, it corrects itself. Here are a couple of snapshots. Drawing A is correct with the correct layout tabs, but as you can see Drawing B has the same layout tabs as Drawing A.....which it should not Quote
tonyj Posted April 12, 2013 Posted April 12, 2013 I Never heard of that before. Sorry I can't be any help, but I'm sure someone here will know the answer. Quote
SLW210 Posted April 12, 2013 Posted April 12, 2013 Could be Graphics Card or driver related. I've seen odd stuff happen on screens when cards were dying. I do recall AutoCAD 2009 being buggy, check and makes sure you have all the updates and service packs. Quote
jiggly_jelloo Posted April 12, 2013 Author Posted April 12, 2013 My Computer is only about a month old, so I should hope that my graphics card isn't dying yet....although I do know it is possible!! I will ask our IT guy to check that for me...I don't have any admin privilidges. He is coming by shortly to finally install my brand spankin new version of Solidworks Quote
SLW210 Posted April 12, 2013 Posted April 12, 2013 Well, with Solidworks, you may not need to even worry about AutoCAD. Quote
