Multiple viewports to one viewport (paper space)
Hello,
Let me start by saying I'm new to AutoCAD, and am learning as I go. I am currently working on a .DWG in Civil3D which has 12 viewports. This particular .DWG causes my computer to lag quite a bit. I was wondering if there was a way of combining viewports in paper space (i.e. taking areas from multiple viewports and displaying them in one viewport), or if I am stuck with the individual viewports? I am just looking to speed up the process, it takes a long time to load the .DWG and work within it, the problem happens to others as well.
.DWG info:
Large area with many smaller sites (retention ponds and such)
All sites must remain in the paper space layout
(I've tried deleting viewports, and that does speed up the process, but again, I need to keep all sites intact).
Computer info:
Windows 7 64-bit
8GB Ram
Intel Core i5-3450 CPU @ 3.10GHz
NVIDIA Quadro FX 1800
Edited by jamesp1426
Start by purging your drawing and get rid of any junk you dont need one of our guys is notoriuos for doing this makes so hard to simply work on one of his dwg's.
Thanks for the reply, I did attempt to purge the file, it did help a little, but it still lags.
Did you use the command line version of the purge command with the dash in front of it? -purge
What is the file size of this drawing?
Perhaps you need to increase the amount of RAM in your computer.
Are there xrefs to this and other drawings your working on where you have this issue? Also do you have any pdfs inserted into the drawing?
I did use that command, and the file size is about 1.19MB. I don't have an issue with other drawings, and others at my work have the same issue with the drawing, so I don't think it's an issue of Ram, I would think 8GB would be enough.
Ski_Me: I do not have an issue with any of the other xrefs, it's just this particular drawing. I have other drawings with the same xrefs, and no issues...it's strange. When I reduce the number of viewports, the drawing processes much faster, the problem is I need to show the 12 different areas in one layout sheet.
Did you purge Regapps first or did you immediately go with the "All" option?
Did you run an Audit on the file to check for and fix any errors?
ReMark: I did use RegApps first, I realized there was a nested reference for a file I didn't need. I removed that and it sped up the process a bit, but it's still slow.
Have you tried auditing the file?
What about 'overkill'?
That can help reduce the size of the file.
1.19 mb is tiny check for linetypes that are tiny dash dot style are reproducing at a tiny scale so really slow things down. We had a dot linetype 10 mins to open dwg.
Have never heard of that issue, although hatching has caused that in a ye olde thread-e.
Must have the same principle behind it.
ReMark and Dadgad, I did run audit and no errors found.
I did use overkill previously, so I know duplicates are not an issue.
I haven't looked into that linetype issue yet, but thanks for the advice.
Have you tried Detaching and then re-Attaching the XREFs?
I have tried that as well...I think now that I've done everything I can think of and looked at some additional suggestions the file is definitely at a more workable speed. It used to take 10 minutes to load, now it's about 2 minutes to start, and the lag time is down from about 5 minutes to almost real-time (30 seconds when switching between model and paper space, maybe less) :)
Thanks everyone for your help. I hope this might help others with similar issues.
