MEPGuy Posted April 15, 2013 Posted April 15, 2013 Hi, Does anyone know a good way to insert pre-made layers into a drawing as needed? I am using AUTO CAD LT and have made up some layers, but chances are not all of them will be used on every project. I have all the layers assembled in a drawing I call "Layers" and rather than go in and manually select the layers I need I am wondering if there is an easier way to do this? Any help would be greatly appreciated. Dan Quote
ReMark Posted April 15, 2013 Posted April 15, 2013 Have you considered using this drawing as the basis of a template? Quote
dbroada Posted April 15, 2013 Posted April 15, 2013 template as ReMark says would be my first choice - you can always purge if you really have to get rid of the excess later or drag them from your base drawing using design centre. Quote
MEPGuy Posted April 15, 2013 Author Posted April 15, 2013 ReMark/dbroada, Thanks. I wasn't sure if there was another way of doing it. I used to work for a company that had some built in routines where you could go to a drop down menu and just load the specific layering groups you wanted. Think this is a LISP(?) routine of some sort. Since I running LT I doubt this would work. In any event I think the template route will work fine. Thanks again. Great forum. Dan Quote
ReMark Posted April 15, 2013 Posted April 15, 2013 LT does not support the use of lisp. I suppose you could try using a diesel macro. Quote
Mike_Taylor Posted April 15, 2013 Posted April 15, 2013 ReMark/dbroada, Thanks. I wasn't sure if there was another way of doing it. I used to work for a company that had some built in routines where you could go to a drop down menu and just load the specific layering groups you wanted. Think this is a LISP(?) routine of some sort. Since I running LT I doubt this would work. In any event I think the template route will work fine. Thanks again. Great forum. Dan It can be done through the combination of scripts and diesel macros as Remark mentioned. Quote
Dadgad Posted April 15, 2013 Posted April 15, 2013 (edited) Template gets my vote too. I can't imagine working without mine. Why bother selecting and loading them, if they can be all be included out of the gate, and purged before saving, or at any other point which seems appropriate? Of course you could create a few different templates, each of which might include a different set of layers, if you are concerned about having lots more layers than you need in your single omni task template. Edited April 16, 2013 by Dadgad Quote
BIGAL Posted April 16, 2013 Posted April 16, 2013 If you must use a script off the top of my head. la n name1 C name1 c 1 lt name1 continuous la n name2 C name2 c 2 lt name2 dashed la n name3 C name3 c 3 lt name3 centreline Quote
RobDraw Posted April 16, 2013 Posted April 16, 2013 Templates are the way to go for starting a file but if you have layer groups that you may need to insert into existing dwgs, you can set up a few .dwgs (In addition to the .dwts, which cannot be inserted as a block.) with a layer group in each and insert them as blocks or cherry pick them using Design Center. You don't need any objects in them, just set up the layers. Quote
SLW210 Posted April 16, 2013 Posted April 16, 2013 You can set up a Button to Insert the drawing as a block. No Lisp needed. Quote
