Kemphas Posted April 15, 2013 Posted April 15, 2013 Anyone know how to set 0 quardinates without screwing with the copy paste base point? I use the command UCS, Object, Select my base point and measure from there rather than cluttering measurement lines; however, without using UCS, Previous when ever i copy and paste the base point for the copy paste is off.. yes i can reset just wondering why it does this. Thank You. Quote
CyberAngel Posted April 15, 2013 Posted April 15, 2013 I'm not sure if this answers your question, but when you paste to coordinates, AutoCAD uses the current UCS, not necessarily the world UCS. Quote
Kemphas Posted April 16, 2013 Author Posted April 16, 2013 Well, If my base isn't moved, when i copy an object if my cursor is any bit close to what i am copying when i paste its to the top right of my cursor (cursor intersection is lowest XY value of total paste). When I move the base point via UCS if i copy, even if cursor is near the object when you paste the pasted object is normally WAY WAY off to the left sometimes out of extents and when Mouse 3 it increases model area. Using UCS Previous fixes the problem.. Bug? Reason? Quote
RobDraw Posted April 16, 2013 Posted April 16, 2013 The UCS needs to be the same in both files in order for copying with base point and pasting with coordinates to work. Copying without using the base point option assigns the base point as lower left extent of the object(s) selected. Quote
Kemphas Posted April 16, 2013 Author Posted April 16, 2013 Not pasting with quardinates, not pasting from one file to the other.. Everything is same file and the problem happens either in Paper space or Model Space. Mind I am using ACDLT 2010 for Electrical Purposes (theres allot of repetition in terminal block's paired wire annotation) Quote
RobDraw Posted April 16, 2013 Posted April 16, 2013 Your explanation is a bit confusing. Can you please post a couple of screen shots showing what the problem is? Quote
Kemphas Posted April 23, 2013 Author Posted April 23, 2013 Sorry I had not responded to this been out of the country. Its not a big deal see screens shots below.... (it is such a pain to have to take these and than get a file sharing site and than post them main reason i didnt do it before i left) anyone have a decent file sharing website that an advertising w****? Quote
RobDraw Posted April 23, 2013 Posted April 23, 2013 You can post files directly using advanced options. Click "Go Advanced" in the bottom right. Please explain what you are trying to accomplish and the steps you are currently taking to get there. Quote
Kemphas Posted April 23, 2013 Author Posted April 23, 2013 I am trying to change the UCS without changing the default Copy Base point of most bottom left (just a simple CTRL+C not Copy with Base Point CTRL+SHIFT+C). The procedure of what i am doing is typed into the previous pictures i posted but i will type them here: I change the UCS to utilize ordinate dimensions to un-clutter the drawing (UCS,Object, (Select Object)) Make my Ordinate measurements Randomly later in the drawing try to copy/ paste something (however if i do not UCS,Previous) the base point is way off and not at the default most lower left corner. Quote
RobDraw Posted April 23, 2013 Posted April 23, 2013 Okay, I think I got it now. The base point is obviously UCS (User Coordinate System) driven. When you change it, it is rotating 180 degrees (Turn on your UCS icon to see this happening.) as well as moving and will affect the rotation of anything inserted. Therefore, the default base point goes from being the lower left to the upper right of the objects you are copying. You may want to look into learning more about the UCS and how it works. Quote
BIGAL Posted April 24, 2013 Posted April 24, 2013 Look into these will hep you UCS save Ucs restore Plan Quote
