MikeP Posted November 17, 2008 Posted November 17, 2008 I need to convert an image file to a dwg. how can i do this or is there a program that can make the conversion? Quote
Strix Posted November 17, 2008 Posted November 17, 2008 what sort of image is it? there are facilities to convert from pdf, but you don't wind up with the full functionality of a real CAD drawing Quote
MikeP Posted November 17, 2008 Author Posted November 17, 2008 what sort of image is it? there are facilities to convert from pdf, but you don't wind up with the full functionality of a real CAD drawing its an image with text in it Quote
MikeP Posted November 17, 2008 Author Posted November 17, 2008 if it could look a metafile it would be great Quote
papagyi Posted November 17, 2008 Posted November 17, 2008 Hey mike!...Image is base on pixel resolution.Autocad base on vector software.The only thing..pdf can change to dwg.But suitable for acad plot to pdf .Other software to pdf will not perfect to convert pdf. Quote
MikeP Posted November 17, 2008 Author Posted November 17, 2008 Hey mike!...Image is base on pixel resolution.Autocad base on vector software.The only thing..pdf can change to dwg.But suitable for acad plot to pdf .Other software to pdf will not perfect to convert pdf. so your saying im screwed? Quote
papagyi Posted November 17, 2008 Posted November 17, 2008 Ha..ha...don't think like that...fri.. This may be not sure perfect answer,i share as i can for you. Quote
Strix Posted November 17, 2008 Posted November 17, 2008 it all depends what it is you're trying to achieve and why if you need a dwg for it's accuracy and functionality you're usually best off redrawing the whole thing you can insert an image file into your new drawing to draw on top of though - preferably with some layer discipline so you can turn your image off if need be Quote
MikeP Posted November 17, 2008 Author Posted November 17, 2008 i need to use this drawing to be cut a cnc, so yes accuracy is important Quote
Guest Posted November 18, 2008 Posted November 18, 2008 Raster to Vector is tricky. Vector: Images created through a sequence of mathematical statements, defining shapes in two-dimensional and three-dimensional space. Thus, giving the date geometric values. (I.e. length, radius, angle etc.) Raster: Images created on a grid in which coordinates and colors of bits are mapped into a given display space. This image data holds no geometric value. I have spent many hours working out ways to convert these. Your best option (& most accurate) is to get a Vector file from your client. (I.e. *.eps, *.pdf, *.ai) These can all be easily translated to *.dwg, or *.dxf files using Adobe Illustrator (Using 'Export' from the File Menu.) Once it is imported into Auto CAD, you will need to explode it into single line entities, then use the flatten command. The flatten command is used to change all of the splines into arcs. After that you only need to join all of the polylines & scale the logo to size. Depending on your router software, you may be able to take the vector file, in its original vector format & bring it right in. If your only option is to use the Raster file, it is fairly easy to trace the image in Adobe Illustrator, but again, it will not be completely accurate. (Just like tracing in Auto CAD.) Quote
MikeP Posted November 18, 2008 Author Posted November 18, 2008 Raster to Vector is tricky. Vector: Images created through a sequence of mathematical statements, defining shapes in two-dimensional and three-dimensional space. Thus, giving the date geometric values. (I.e. length, radius, angle etc.) Raster: Images created on a grid in which coordinates and colors of bits are mapped into a given display space. This image data holds no geometric value. I have spent many hours working out ways to convert these. Your best option (& most accurate) is to get a Vector file from your client. (I.e. *.eps, *.pdf, *.ai) These can all be easily translated to *.dwg, or *.dxf files using Adobe Illustrator (Using 'Export' from the File Menu.) Once it is imported into Auto CAD, you will need to explode it into single line entities, then use the flatten command. The flatten command is used to change all of the splines into arcs. After that you only need to join all of the polylines & scale the logo to size. Depending on your router software, you may be able to take the vector file, in its original vector format & bring it right in. If your only option is to use the Raster file, it is fairly easy to trace the image in Adobe Illustrator, but again, it will not be completely accurate. (Just like tracing in Auto CAD.) what if i do not have illustrator? Quote
Guest Posted November 18, 2008 Posted November 18, 2008 what if i do not have illustrator? Then you are stuck tracing it in Auto CAD, with out any accuracy. If you can get the vector file, you can see if your router software can view it. Quote
shift1313 Posted November 18, 2008 Posted November 18, 2008 there really isnt a good way to do this accurately. If you dont mind me asking, what is the drawing of. are there any dimensions on it? can you redraw it? When i make drawings that need to contour to something else i make a pencil tracing or scan the object in using a scanner or photocopier then trace it in cad using a spline to the best of my ability. This works well for most things but if you have a tolerance you need to hit good luck is all i can say. just as said above, jpeg carries no information that is usable. Quote
