Hi,
I have received a drg that when you look at the viewport in layout, all the line colours have changed to white, but in model space they are their designated colours by layer. It would be good to know how this is done, can anybody clarify?
Go to the layout and switch to model space. Open the Layer Manager. Check the VP Color column. If it's different from the general layer color, you've found your discrepancy. Change the VP Color back to the general color. You should be able to right click on the layer and use Remove Viewport Overrides.
It could also be a setting in the pagesetup, open that up and uncheck display plot style, it is in the upper right.
