How do I cut into the side of a circle that has been extruded and subtracted?
Can you post an image or an actual DWG file so we can see what you are dealing with?
i have uploaded it. thanks for your help
You could try the PROJECTGEOMETRY command but I don't believe that would give you a true representation. The topic has been discussed before. The person who would know the best answer would be JD Mather but he'll also tell you this is a task better suited to Inventor.
