hi guys,
Im trying to insert a block into autocad, via a button/ check box.
my code is as follows:-
Private Sub
OptionButton1_Click()
Dim insertion point (0 to 2) as double
Dim blockrefobj As AcadBlockReference
InsertionPnt(0) = 0 : insertionPnt(1) = 1 : insertionPnt(2) = 0
'insert the block
' modify drawing and path name as nessesary for your system.
Set blockrefobj = ThisDrawing.Paperspace.InsertBlock(insertionPnt, "C:\Users\bladest\Desktop\vba\new block1345.dwg", 1, 1, 1, 0))
'in r14, no Z-scale required
Zoomall()
'in r14, use ThisDrawing.ActiveViewport.ZoomAll
End Sub
I get a 'syntax error', 'identifier expected' followed by 'statement is not valid in a namespace'
could anyone please trouble shoot this for me? it would be much appreciated :)
obviously once i get this code working, i will be able to apply it to multiple blocks? am i correct in saying this?
cheers forum.
firstly, you will get told off by one of the moderators for not using code tags. Hit on the # tool and put your lines of code between the tags..
next, you have declared your variable with the Dim statement incorrectly in that there shouldn't be a space, and then you used it differently in the code. These two lines should be identical.
Dim [color=red]InsertionPnt[/color] (0 to 2) as double
[color=red]InsertionPnt[/color](0) = 0 : [color=red]insertionPnt[/color](1) = 1 : [color=red]insertionPnt[/color](2) = 0
if you start the VBA module with Option Explicit you will get a syntax error if you try to use a varaible that you haven't declared. This is a good thing. It would have shown up the above errors immediately.
