bm23 Posted April 19, 2013 Posted April 19, 2013 I just started on a new project and I'm at the rendering stage. My previous project, also a very complex architectural model, was rendered at 100% CPU usage. For my current project, CPU usage only goes up to about 33%, which makes the rendering time extremely long. Any idea what may have caused this? My specs are as follow: 3DS Max 2012 + Vray 2.3 Core i7 3770k (no overclock, yet) 32gb DDR3 RAM GTX 560 OC Quote
bm23 Posted April 19, 2013 Author Posted April 19, 2013 Haha, I think i just found the solution. I increased the dynamic RAM limit from 4.9gb to 20gb. It seems to be rendering at full load now. Shall update this thread if this turns out to be a permanent solution Quote
Raudel Solis Posted April 27, 2013 Posted April 27, 2013 Haha, I think i just found the solution. I increased the dynamic RAM limit from 4.9gb to 20gb. It seems to be rendering at full load now. Shall update this thread if this turns out to be a permanent solution Here is another tip, Set the value to 0 and it will use as much ram as it wants, Careful though you might not have enough ram for certain scenes. Quote
