2D polyline to a surface
Skyhigh
 Share
Hello All,
I have created a series of splined lines into a polyline (pedit) which I want to extrude. When I extrude the polyline I only get an extruded polyline and not a surface. I need to create a mesh or make the surface a face to extrude to make a solid. I have not used AutoCad for some years and have forgotten how to do this. I know that I am making an incorrect procedure here somehow. Can anyone give me some help or steer me into the correction.
Thank you,
If your polyline is a closed one, the result of its extrusion will be directly a solid. Can you post a sketch of what you are looking to achieve?
Welcome back, and to CADTutor. :)
You might want to try the PRESSPULL command, which is a bit more forgiving than the EXTRUDE command.
As Mircea mentioned, if you can start with a CLOSED polyline Extrude will generate a 3D Solid.
  • 4 weeks later...
Hi All,:D
Been traveling once again. Guys thanks for your help. After I returned and saw your replies.. I figured it all out. I was using join then close instead of close then join..
Thank you,
Skyhigh,
Some days you eat the bear, some days the bear eats you..
 Share
