Command line is not opening a dialogue box?
i have been using the MAPIINSERT command successfully all day to bring in orthorectified TIF, and just recently, i got the following error:
There are no valid MS Jet providers installed
and now the command line is waiting for a file name instead of opening a windows explorer tab that allows me to navigate to the file?
did i inadvertent change an import setting?
tia!!
In AutoCAD Vanilla, the system variable responsible of controling the dialog for file browse is FILEDIA; when set to 1 it works via a dialog box instead of command prompt. Not sure if will help in your case, too.
If somehow FILEDIA=1 fails, you can input a ~ sign ("tilde") in the command prompt to trigger the classic dialogue window.
That worked, great thanks! FILEDIA got turn to "0".
