alijahed Posted November 17, 2008 Posted November 17, 2008 Hi All, It's my first time coming here in LISP forum! can u please have look on http://www.cadtutor.net/forum/showthread.php?t=29220 Dave said maybe you guys can find a solution. Cheers Quote
Raggi_Thor Posted December 16, 2008 Posted December 16, 2008 Yes. But did you try to open the rectangle drawing and move objects so that the basepoint (usually the origin) is on the corner you want? You can use MOVE and select your upper right corner and the type 0,0. You can also change the baspepoint, type BASE and snap to upur corner. Then save this file and reinsert. Quote
