BIGAL Posted November 17, 2008 Posted November 17, 2008 Does anybody have a lisp or vba to convert an arc to a series of chords. The user would nominate the number of chords per arc. Just needed urgently Quote
Strix Posted November 18, 2008 Posted November 18, 2008 how many of these things do you need to do? if it's urgent, can you not use DIVIDE or MEASURE to produce one more node along the arc than chords you need, then join the nodes with lines with your NODE OSNAP on? Quote
BIGAL Posted November 18, 2008 Author Posted November 18, 2008 Need to do 100's hence just find all arcs and do it it does not matter if arcs are different sizes. Quote
ASMI Posted November 18, 2008 Posted November 18, 2008 For multiple Arcs, Circles, Ellipses, Polylines and Splines (any AutoCAD curves): (defun c:CurvesToSegments(/ cSet sLen cLen sDis ptLst oOsn eLst cAns vCnt lPt) (vl-load-com) (princ "<<< Select curves to transform >>>") (if (setq cSet (ssget '((0 . "*POLYLINE,SPLINE,ARC,CIRCLE,ELLIPSE")))) (if(setq sLen(getdist "\nSpecify segment lentgth: ")) (progn (setq oOsn(getvar "OSMODE")) (setvar "CMDECHO" 0)(setvar "OSMODE" 0) (foreach itm(setq eLst(vl-remove-if 'listp (mapcar 'cadr(ssnamex cSet)))) (setq sDis 0.0 cLen(-(vlax-curve-getDistAtParam itm (vlax-curve-getEndParam itm)) (vlax-curve-getDistAtParam itm (vlax-curve-getStartParam itm))) ); end setq (if(= "LWPOLYLINE"(cdr(assoc 0(entget itm)))) (progn (setq vCnt 1 ptLst(list(vlax-curve-GetPointAtDist itm sDis))) (while(and (<= sDis cLen) (vlax-curve-GetPointAtParam itm vCnt) (setq cPt(vlax-curve-GetPointAtDist itm sDis)) ); end and (if(= 0.0(vla-GetBulge(vlax-ename->vla-object itm)(1- vCnt))) (setq ptLst(append ptLst (list(vlax-curve-GetPointAtParam itm vCnt))) sDis(vlax-curve-GetDistAtParam itm vCnt) ); end setq (progn (while(<= sDis(vlax-curve-GetDistAtParam itm vCnt)) (setq cPt(vlax-curve-GetPointAtDist itm sDis) ptLst(append ptLst(list cPt)) sDis(+ sDis sLen)) ); end while (setq ptLst(append ptLst (list(vlax-curve-GetPointAtParam itm vCnt)))) ); end progn ); end if (setq vCnt(1+ vCnt)) ); end while ); end progn (while(and (<= sDis cLen) (setq cPt(vlax-curve-GetPointAtDist itm sDis)) ); end and (setq ptLst(append ptLst(list cPt)) sDis(+ sDis sLen)) ); end while ); end if (if(not(equal(setq lPt(vlax-curve-getEndPoint itm))(last ptLst))) (setq ptLst(append ptLst(list lPt))) ); end if (command "_.pline")(mapcar 'command ptLst)(command "") (setq ptLst nil) ); end foreach (initget "Yes No") (setq cAns(getkword "\nRemove old curves [Yes/No] <Yes>: ")) (if(or(null cAns)(= cAns "Yes")) (mapcar 'entdel eLst) ); end foreach (setvar "CMDECHO" 1)(setvar "OSMODE" oOsn) ); end progn ); end if ); end if (princ) ); end of c:CurvesToSegments Quote
lpseifert Posted November 18, 2008 Posted November 18, 2008 an amateur's stab at it... not as eloquent as ASMI's asks for number of chords, not length (defun c:test (/ oldecho obj div endpt totlen arclen chrdpt dist newpt) (vl-load-com) (setq oldecho (getvar "cmdecho")) (setvar "cmdecho" 0) (setq ent (entsel "\nPick arc: ") obj (vlax-ename->vla-object (car ent)) div (getint "\nEnter number of chords: ") endpt (vlax-curve-getEndPoint obj) totlen (vlax-curve-getDistAtPoint obj endpt) arclen (/ totlen div) chrdpt (vlax-curve-getPointAtDist obj 0) dist 0 ) (repeat div (setq newpt(vlax-curve-getPointatDist obj (+ arclen dist))) (command "line" chrdpt newpt "") (setq dist (+ arclen dist)) (setq chrdpt newpt) );repeat (setvar "cmdecho" oldecho) (princ) );defun Quote
BIGAL Posted November 18, 2008 Author Posted November 18, 2008 Thank you very much I will test them out today. Quote
