Casio47 Posted April 25, 2013 Posted April 25, 2013 Hello All... So I have this drawing, which has been annihilated by many different people. One area of concern (among many) is the drawing units...some objects are in inches, some in Millimeters, some in feet, etc... Question: Is there a way to change the entire drawing to inches, so if I select an object...any object, properties will have it in inches. Or, if I get area of an object, it will read in square inches? AutoCAD 2012 Thanks for the help Quote
Dadgad Posted April 25, 2013 Posted April 25, 2013 Yes. Use the -DWGUNITS command (include the hyphen). Read the prompts and open your command history window f2 so you can see enough lines that you really understand what is going on with it. You might want to creat a copy and work on it, until you are sure you have acquired your intended results. Quote
Casio47 Posted April 25, 2013 Author Posted April 25, 2013 Well, the good news is we're half way there...So I did this, and the units are all in inches (architectural setting), no matter what I click on. So that is Great! However, the actual distance measurement is way off. For example: if I find area of a Rest Room, which is approximately 600 sq.ft. the new measurement is now 375,144 sq.ft. Something did not make the trip? Good thing I took your advice and working on a copy! Quote
rkent Posted April 25, 2013 Posted April 25, 2013 Hello All...So I have this drawing, which has been annihilated by many different people. One area of concern (among many) is the drawing units...some objects are in inches, some in Millimeters, some in feet, etc... Question: Is there a way to change the entire drawing to inches, so if I select an object...any object, properties will have it in inches. Or, if I get area of an object, it will read in square inches? AutoCAD 2012 Thanks for the help All the objects in a drawing are using the same units of measure. If you set units to Arch or Decimal your object will still be the same size. How did you arrive at the conclusion that your objects were in different units? From there we can help you the rest of the way. Or take the easy way and post the drawing or a small portion of the drawing. Quote
JD Mather Posted April 25, 2013 Posted April 25, 2013 However, the actual distance measurement is way off...... If the actual (that is - the measured) distances are off, you will need to Scale to get the drawing at 1:1 (same as the real world). From there you can tackle getting the annotation (dimensions) correct if needed. Quote
Casio47 Posted April 25, 2013 Author Posted April 25, 2013 On the drawing, there are annotations of square footage. For the restroom, it was already measured at 600 square feet, so when I used the area command, i got 375,144 for square feet. I believe the problem was when I got the file, I went to options and changed the default scale to 1:1, because it was originally something like 1:500...something really stupid. How do I post a small portion for you to view? For example, I could post the Cafeteria, which is supposed to measure at 2,870 sq. ft....it's way off too Quote
rkent Posted April 25, 2013 Posted April 25, 2013 On the drawing, there are annotations of square footage. For the restroom, it was already measured at 600 square feet, so when I used the area command, i got 375,144 for square feet. I believe the problem was when I got the file, I went to options and changed the default scale to 1:1, because it was originally something like 1:500...something really stupid. How do I post a small portion for you to view? For example, I could post the Cafeteria, which is supposed to measure at 2,870 sq. ft....it's way off too Hit reply, use the Go Advanced button in lower right, find manage attachments, follow the steps from there. Quote
Casio47 Posted April 25, 2013 Author Posted April 25, 2013 I think that is it...there's the Cafeteria Hosur, India Cafteria.dwg Quote
rkent Posted April 25, 2013 Posted April 25, 2013 Your drawing was done in mm, use the previously mentioned -dwgunits command and go from mm to inches. Or simply scale all objects by 10/254. Quote
Casio47 Posted April 26, 2013 Author Posted April 26, 2013 I originally did the -dwgunits command and changed from mm to inches, this is when the problems began. In the Cafeteria drawing, if I take the area of the rectangle, I get about 1,850,349 sq. ft., instead of the original 2,870 sq. ft.? These "way off" numbers are present over the entire drawing? Thanks for the help Quote
blaconi2000 Posted April 28, 2013 Posted April 28, 2013 The easiest way to convert the drawing would be to set the units back to mm and save it. Then start a new drawing and set the units in it to inches. Insert the saved drawing (with explode checked) into the new drawing and it will be should be scaled correctly. Tried it with the example you posted and it worked as desired. Quote
danellis Posted April 29, 2013 Posted April 29, 2013 It sounds like your drawing was drawn in inches with the unit set to millimeters (this sort of thing is frightfully common. My own firm does it as a matter of policy). When you then converted from mm to inches you quite understandably told it to scale everything which meant that something that should have measured an inch ended up measuring 25.4". dJE Quote
Dadgad Posted April 29, 2013 Posted April 29, 2013 Precisely. The -DWGUNITS command is really helpful, but due diligence is required. There are enough options there to fix any problem, but in order to know which ones to select, you need to have some basic information going in. There are way too many folks who are absolutely clueless as to what units they are really using in their drawing database, which is the key. The use of an appropriate template goes a very long way towards rectifying these sorts of issues. Autocad defaults to IMPERIAL templates, unless instructed to do otherwise by resetting your QNEW template preference in OPTIONS on the FILE tab to a different one. Typically the metric templates have ISO at the end of their names. Quote
Casio47 Posted April 29, 2013 Author Posted April 29, 2013 great. It sounds like what should have been done, was before the objects in the second file was pasted into the target file, it should have been converted to inches to match the target file? Quote
Ski_Me Posted April 29, 2013 Posted April 29, 2013 This is why I think the metric system is the spawn of satan. I may not know how long 3 meters is but I sure as hell know how long 9 ft is. Also all the damn tools I got to buy to cover all the metric crap I gotta work on. Quote
blaconi2000 Posted April 29, 2013 Posted April 29, 2013 Casio47, It should do that. In the more recent versions, if you insert a drawing done in one unit (such as mm) the program will convert it to the units of the drawing it's inserted into (such as inches). Quote
Dadgad Posted April 29, 2013 Posted April 29, 2013 great. It sounds like what should have been done, was before the objects in the second file was pasted into the target file, it should have been converted to inches to match the target file? The problem is that there are so many different ways to screw this up. Somebody wishes, meant to, or thinks they are drawing in one kind of database unit, and may or may not have set their insert units to match and automatically scale accordingly. Someone else who is collaborating on the project might or might not know what units they are using, and it just gets worse the farther afield you go. -DWG UNITS can fix it all, but you have to be able to figure out what you want to tell it to do first. Due diligence. Quote
