hemuni Posted April 29, 2013 Posted April 29, 2013 When i invoke the vlide command the editor window just blinks and then disappears again. The editor is loaded and I can use alt+tab to switch to it, but it still doesn't show up when selected. I tried removing any previously loaded lisp files in case this is caused by an error in my code, but no go. Does anybody know what could be causing this? Is there an ini file or registry entry that i could reset or something like that? Quote
Tharwat Posted April 29, 2013 Posted April 29, 2013 Try to restart Autocad or even the PC and try again . Quote
hemuni Posted April 29, 2013 Author Posted April 29, 2013 This was of course the first thing I did. It is not solved by a simple restart Quote
hemuni Posted April 29, 2013 Author Posted April 29, 2013 The dialog was of screen, alt+spacebar and select move did the trick Quote
Tharwat Posted April 29, 2013 Posted April 29, 2013 The dialog was of screen, alt+spacebar and select move did the trick What did you move ? Quote
hemuni Posted April 29, 2013 Author Posted April 29, 2013 What did you move ? I'm using two monitors and I think when switching resolution on the second monitor it reset the size and position of the vlisp editor window. I pressed alt+spacebar and selected move, witch give you the option to move any window with the arrow keys. Silly problem, but it was driving me crazy Quote
Tharwat Posted April 29, 2013 Posted April 29, 2013 The dialog was of screen, alt+spacebar and select move did the trick You should have mentioned and thanked the guy who helped with the problem since that it is in another forum . http://www.theswamp.org/index.php?topic=44488.msg497443#msg497443 Quote
