Hi All,
Anyone can help my problem, I have VBA code it's working fine in AutoCAD 2008. but it's not woeking in AutoCAD 2011. after hide the forms, i can't get my cad scr. thanks for your helping.
That sometimes happens when you start your macro from the debug window. Try starting it from AutoCAD.
Thanks for your reply. It's not working. i used get point fountion to get the point from user. after hiding the forms. user can't acess AutoCAD :(
Try stepping through your code in the debug window to the code before you cant access the graphic screen. Then post the problem area in your code so that we can have a look at it.
I can't get point from CAD. using below code.
see next post.
Edited by ramanusu
code removed
see my code below.
Private Sub CommandButton5_Click()
On Error GoTo ErrHandler
Pump_curve_main.Hide
ThisDrawing.Activate
Call pick_point
TextBox11.text = CStr(Round(scale_pt(0), 0))
TextBox12.text = CStr(Round(scale_pt(1), 0))
Pump_curve_main.Show
Exit Sub
ErrHandler:
MsgBox "Please Pick a Point Error: " & _
Err.Description, vbDefaultButton1, "Pump Curve Creator"
Exit Sub
End Sub
Sub pick_point()
scale_pt = ThisDrawing.Utility.GetPoint(, "Pick a Scale origin point:")
End Sub
I tried your code and it works fine, I can pick a point and the rounded coordinates are displayed in two text boxes.
What I don't see in your code is the declaration for the variable 'scale_pt'. I declared it as a variant
Dim scale_pt As Variant
Check your declaration of the variable and note that there are no parentheses { () } in the declaration.
While using that point i try to draw a line it's gave a error
"The object invoked has disconnected from clients"
To draw a line you need at least two points. You need to save the point you picked in a variable, then repeat the point picking and save that point in another variable. Then you can use these two points to draw your line.
BTW did you manage to get your code to work?
you re right. I get that point and add some value in y axis for 2nd point. i have draw line while form showing time. it's draw in AutoCad 2008 but it's not working in Autcad 2010. i don't know why :(
