markv Posted May 1, 2013 Posted May 1, 2013 I found this lisp on another site from a user with the handle jmcshane. Thanks for that! It works well with adding a specified integer to a selected number with multiple copies. (defun c:copyinc (/ IncVal TextObj NewPos TextVal NewTextObj) (vl-load-com) (setq IncVal (fix (getreal "\nEnter Incremant Value :"))) (setq TextObj (vlax-ename->vla-object (car (entsel "\nSelect Mtext Object :"))) ) (while (setq NewPos (getpoint "\nSelect new position : ")) (setq TextVal (atoi (vla-get-textstring TextObj))) (setq NewTextObj (vla-copy TextObj)) (vla-move NewTextObj (vla-get-InsertionPoint NewTextObj) (vlax-3D-Point NewPos) ) (vla-put-textstring NewTextObj (+ IncVal TextVal)) (setq TextObj NewTextObj) ) (princ) ) I would like it to function the same way but have the selected number "10410-13" for example get copied and change to this example "10414-17". any help would be appreciated. Quote
BlackBox Posted May 1, 2013 Posted May 1, 2013 Give this a try: (vl-load-com) (defun c:CopyInc (/ n ss otext insertionPoint textString pt oNewText i newString ) (if (and (setq n (getint "\nEnter increment value (integer): ")) (setq ss (ssget ":S:E:L" '((0 . "MTEXT,TEXT") (1 . "*#-#*")))) (setq oText (vlax-ename->vla-object (ssname ss 0))) ) (while (setq pt (getpoint "\nSpecify new insertion point(s): ")) (vla-move (setq oNewText (vla-copy oText)) (vla-get-insertionpoint oText) (vlax-3d-point pt) ) (vla-put-textstring oNewText (strcat (substr (setq newString (itoa (+ n (atoi (strcat (substr (setq textString (vla-get-textstring oText)) 1 (setq i (vl-string-search "-" textString)) ) (substr textString (+ 2 i)) ) ) ) ) ) 1 i ) "-" (substr newString (1+ i)) ) ) (setq oText oNewText) ) (cond (n (prompt "\n** Nothing selected ** ")) ((prompt "\n** Must enter an increment value ** ")) ) ) (princ) ) Quote
markv Posted May 1, 2013 Author Posted May 1, 2013 Getting closer. I need to add to the first number before the dash and the numbers after the dash. Like this 10410-13 copies too 10414-17 Quote
BlackBox Posted May 1, 2013 Posted May 1, 2013 Getting closer. I need to add to the first number before the dash and the numbers after the dash. Like this10410-13 copies too 10414-17 I don't know what results you're getting on your end, but a text entity with a TextString = "10410-13" _does_ copy as "10414-17"... Here's a screen shot using 404 (the difference between 1041013 and 1041417) as my increment: Quote
markv Posted May 1, 2013 Author Posted May 1, 2013 I am sorry was using the number "4" works awesome. I am feeling a bit sheepish Quote
BlackBox Posted May 1, 2013 Posted May 1, 2013 I am sorry was using the number "4" works awesome. I am feeling a bit sheepish No worries; I'm happy to help. Quote
pBe Posted May 2, 2013 Posted May 2, 2013 Why not (vla-put-textstring oNewText (strcat (substr (setq newString (itoa (+ n (atoi (strcat [b][color="blue"](itoa (+ (atoi (substr (setq textString (vla-get-textstring oText)) 1 (setq i (vl-string-search "-" textString)) ) ) n )[/color][/b] ) (substr textString (+ 2 i)) ))))) 1 i ) "-" (substr newString (1+ i)) ) ) and type 4 instead of 404? or 1 than 101? Here's another (defun c:CopyInc2 (/ n ss otext insertionPoint textString pt oNewText ) (if (and (setq n (getint "\nEnter increment value (integer): ")) (setq ss (ssget ":S:E:L" '((0 . "MTEXT,TEXT") (1 . "*#-#*")))) (setq oText (vlax-ename->vla-object (ssname ss 0))) ) (while (setq pt (getpoint "\nSpecify new insertion point(s): ")) (vla-move (setq oNewText (vla-copy oText)) (vla-get-insertionpoint oText) (vlax-3d-point pt) ) [b][color="blue"][color="#8b0000"] (setq NewStr (mapcar '+ (read (Strcat "(" (vl-string-subst " " "-" (vla-get-textstring Otext)) ")")) (list n n))) (vla-put-textstring oNewText (strcat (itoa (Car NewStr)) "-" (itoa (Cadr NewStr))))[/color][/color][/b] (setq oText oNewText) ) (cond (n (prompt "\n** Nothing selected ** ")) ((prompt "\n** Must enter an increment value ** ")) ) ) (princ) ) command: CopyInc2 HTH Quote
