Is there a way to do this within 2012 or would I need to use a script?
Besides using a LISP routine, I use the FILTER tool and have a selection set saved. Just make sure the only filter is "Block" and you can drag+select the entire drawing to grab only blocks. Usually I have to do this a few times due to nested blocks.
How do i use QSelect + Explode
type QSELECT, Object Type = Block, Operator = Select All. Then, EXPLODE.
Would suggest BURST instead of EXPLODE
Thanks for the information.
