Hoping someone can help me out.
I found a lisp routine that labels a line with a bearing and distance.
It labels the line with both. Can some one figure out how to break
it into 2 seperate routines. One that just labels the line with the
bearing and the other with just the distance.
Note, the bearing routine needs to maintain the "degree" symbol behind
the first number, and the distance needs to maintain the "(')" symbol
at the end of the length of the line.
Thanks
bearing_and_distance.LSP
What about 3 separate routines
(defun c:bad ()(badder 3));
(defun c:badA ()(badder 1))
(defun c:badD ()(badder 2))
Hang on. is this a homework ? there's quite a number of posters requesting "help" but ending up just copying the code?
[ a code is at the ready ] Hope you don't mind us asking if this is one those cases.
There are other ways to do modify the code. Here's how i would approach this.
(defun badder (mode / _pad0 c_textstyle c_textsize c_ltscale pt1 pt2 mid p_)
 [color="blue"](defun _pad0 (st)
   (foreach itm '(("*d#'*" 100) ("*'#\"*" 39))
     (if (wcmatch st (Car itm))
       (setq st
              (strcat
                (substr st 1 (1+ (setq p (vl-string-position (cadr itm) st))))
                "0"
                (substr st (+ p 2))
   st
 )[/color]
 (setq c_textstyle (getvar "textstyle"))
 (setq c_textsize (getvar "textsize"))
 (setq c_ltscale (getvar "ltscale"))
 (if (= "textsize" 0)
   (setvar "textsize" 1)
 (setq pt1 (getpoint "\nPick the first Point: ")
       pt2 (getpoint pt1 "\nPick the second Point: ")
 [color="blue"](setq mid (mapcar '(lambda (m n)
                      (* 0.5 (+ m n))
                   pt1
                   pt2
 )[/color]
[color="blue"] (entmakex
   (list
     (cons 0 "TEXT")
     (cons 10
           (Setq p_ (polar mid
                           (+ (setq ang (angle pt1 pt2)) (/ pi 2.0))
                           (* 0.75 c_textsize)
     (cons 11 p_) (cons 40 c_textsize) (Cons 50 ang)
     '(41 . 0.80) '(72 . 4) '(73 . 3)
     (cons 1
       (vl-string-subst "%%d" "d"
         (_pad0
           (cond
             ((eq mode 1) (angtos ang 4 4))
             ((eq mode 2) (strcat (rtos (distance pt1 pt2) 2 2) "'"))
             ((eq mode 3)
              (strcat (angtos ang 4 4) " " (rtos (distance pt1 pt2) 2 2) "'")
   )[/color]
HTH
