jiggly_jelloo Posted May 3, 2013 Posted May 3, 2013 Does anyone know if a file can be generated from solidworks that can be opened in Acad 2009? I tried a .sat file and using the acisin command in Acad, but it won't read the file. Thanks Quote
JD Mather Posted May 3, 2013 Posted May 3, 2013 Autodesk product will only read up to ACIS (*.sat) v7. In SolidWorks when you Save As ACIS, be sure to click the Options button before saving and set to ACIS r7. Quote
jiggly_jelloo Posted May 3, 2013 Author Posted May 3, 2013 Thank you JD...worked perfectly! Happy Friday! Quote
