ittayd Posted May 4, 2013 Share Posted May 4, 2013 Hi, How can I draw a 3d arrow in autocad 2012? (where the arrow head is a cone, or something that appears in all view angles). Assuming the answer will be a cone and line grouped, how can I rotate them (I seem to be able to rotate only in the xy plane) Quote Link to comment Share on other sites More sharing options...
Tyke Posted May 4, 2013 Share Posted May 4, 2013 A cone and a rod grouped together would work fine. In the 3D workspace there is a 3D-Rotate command or you could just use the 3D-Orbit if you just want to rotate for viewing. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 4, 2013 Share Posted May 4, 2013 No surprise there, as ROTATE is a 2D command and will only work on an XY plane. As Tyke suggested, use 3DROTATE instead. Quote Link to comment Share on other sites More sharing options...
