ittayd Posted May 4, 2013 Posted May 4, 2013 Hi, How can I draw a 3d arrow in autocad 2012? (where the arrow head is a cone, or something that appears in all view angles). Assuming the answer will be a cone and line grouped, how can I rotate them (I seem to be able to rotate only in the xy plane) Quote
Tyke Posted May 4, 2013 Posted May 4, 2013 A cone and a rod grouped together would work fine. In the 3D workspace there is a 3D-Rotate command or you could just use the 3D-Orbit if you just want to rotate for viewing. Quote
Dadgad Posted May 4, 2013 Posted May 4, 2013 No surprise there, as ROTATE is a 2D command and will only work on an XY plane. As Tyke suggested, use 3DROTATE instead. Quote
