I've migrated from 2005 to 2014 LT and wondered if they have added to the hatch commands. I've looked and haven't found anything. Is there a command that you can pick a hatch pattern already shown on the drawing and make that pattern the existing one to use? I sometimes have multiple hatch patterns and scales, and wanted a quick way to go from one to another without lisp help.
Thanks
Dan
Draw > Hatch > Options > Match Properties.
Another option will be to use the Inherit Properties button from BHATCH's command dialog.
Thanks for the reply's. Bhatch seems to change the dialog box to the new hatch patterns after you use it, which works for me. I'm trying how to make my own button with "Inherent Properties" on it, but I haven't figured out how to do it, or if it's possible.
