dbroada Posted May 9, 2013 Posted May 9, 2013 This is a general question about VB.Net rather than AutoCAD VB.Net but I think the question is general. In the past (VB6) I have created an array of radio buttons by copy & paste which gives me something like button1(0), button1(1), button1(n) and button2(0), button2(1), button2(n) where button1 and button2 worked as independant groups. It would appear that in VB.Net you can't (I can't?) create an array of buttons. I can get them to behave as a group by putting them in a container but it looks harder to check which one is selected. Have I missed something? Quote
Tyke Posted May 9, 2013 Posted May 9, 2013 Try something like this in your form load event: optLine.Checked = True optSymbol.Checked = False optPoint.Checked = False That sets the initial state of the option buttons. Then use this to change their states: If crCodeLine.sType = "Line" Then optLine.Checked = True ElseIf crCodeLine.sType = "Symbol" Then optSymbol.Checked = True Else optPoint.Checked = True End If To read their states use: If optLine.Checked = True Then strType = "Line" ElseIf optSymbol.Checked = True Then strType = "Symbol" Else strType = "Point" End If Or if you have a lot of them you can use a case select instead of if statements. Quote
dbroada Posted May 9, 2013 Author Posted May 9, 2013 Thanks Tyke. do you have to use containers to group them or can you mix twodifferent sets within one container? I have been using CASE SELECT based on the array position. Do I look at the opt.Name to work it now? Quote
Tyke Posted May 9, 2013 Posted May 9, 2013 You need each set of radio buttons in their own GroupBox, as when you change the state of one to 'checked' ALL of the others in the container are then automatically set as 'unchecked'. If you don't want to see the GroupBox Text set its Text property to an empty string. To work the radio buttons you have to use their names and properties (eg 'optLine.Checked = True'). I still use the prefix 'opt' for radio button names, but that is just a hangover from VBA where they are called option buttons. Quote
dbroada Posted May 9, 2013 Author Posted May 9, 2013 Thanks again, it sounds like I am heading in the right direction then. I too prefer optName. One more (?) question. With an array it is easy to set which opt is highlighted.... optButton1(x).checked=true is this possible just given x or do you have to do a case|select? Quote
Tyke Posted May 9, 2013 Posted May 9, 2013 Not as far as I know. You have to use the radio button's name. Perhaps I misled you a bit with the case select possibility. I use it when setting the radio buttons, if a condition is true then set the relevant radio button to checked. This: If crCodeLine.sType = "Line" Then optLine.Checked = True ElseIf crCodeLine.sType = "Symbol" Then optSymbol.Checked = True Else optPoint.Checked = True End If would become: Select Case crCodeLine.sType Case "Line" optLine.Checked = True Case "Symbol" optSymbol.Checked = True Case Else optPoint.Checked = True End Select You can't loop through all of the radio buttons in your GroupBox using Select Case. Quote
dbroada Posted May 9, 2013 Author Posted May 9, 2013 I read a value from the registry so I can do something like this... Select Case myValue case = 1 optButton.checked=true etc. It works but its a lot longer than the one I posted above. I'm just glad I've only got 8 elements. Quote
Tyke Posted May 9, 2013 Posted May 9, 2013 That's correct. Who ever said .NET was more concise than VB6? We all know much better than that Dave. Perhaps that's one reason why I still do VBA as well as .NET. But at least you only have to mark one of the radio buttons as checked, all the others in the GroupBpx then automatically become unchecked. Keep on coding you never know when BB might show up Quote
