Can anyone tell me how I rotate a block but set the text to stay readable.
At the moment I have a 600x600 light fitting with a Tag inside for typing the letter of the fitting. E.G. Type A, B, C
I have a rotate function also so I can rotate the fitting to the orientation of the room.
But when I rotate the fitting the text rotates also, therefore if I turn the fitting round 90 degrees the text is on its side.
How do I rotate the block but leave the text orientation the correct way?
I am having exactly the same Problem this morning! From what I've read so far, it's only possible when the Text in the Block is set as an Attribute.....
you can create a block with a rotate parameter so that you only rotate the geometry but not the text but this will only work if you use the rotate action. If you subsequently rotate the whole block the text remains in its defined position.
am i right in saying there's no way of changing that with existing blocks?
there is no way (that I know of) to have text rotate within a block that is inserted at a rotation but you can convert the block to a dynamic one to add the rotation parameter.
As you are using 2013 there may be a geometric constraint that can be utilised but I have not got enough experience with GC to say.
HELP BLOCKS.dwg
Take a look at the attachments. These 2 blocks have been created in a way that I want to do my ones. Notice as you rotate the blocks using the rotate parameter that the text stays in the same orientation.
OK, I understand your question now.
What you need to do is add the rotate parameter to your block and also add a point parameter at the insertion point of your text/attribute. Select everything you want to rotate EXCEPT the text but make sure you include the point.
Create a move action referenced to the point and select the text. You may have to ensure "allow chain actions" on the point.
Now when you rotate your block the point rotates with everything else which then triggers the move action for the text. Note, if you are using attributes, you MUST set LOCK POSITION for them to move.
Re: Text Inside Block Rotation Problem
Options
07-26-2011 05:19 PM in reply to: cfreels
You can create a dynamic block so that you can use a dynamic grip to rotate the block but keep the text upright. Noted that if you rotate it using ROTATE command then the text will be rotated as well. See attached example.
Attachments: icon_attachment.png ROTATING_DYNAMIC BLOCK.dwg ‏60 KB
Don't know it the above will do what you want or not but found this in another forum and thought i would pass it on
Thanks this is exactly how I wanted to do it. Cheers
