Hi,
I'm trying to do an edit on an xref via the host file. I make the changes go to save, select 'Save changes' not discard changes.
After clicking 'OK' it reverts as if I chose discard.
(I have previously been making changes successfully in this way.)
Is someone in the xref that you are trying to refedit? Also there is an options under options dialogue box in the external references area that lets you control whether an drawing can be refedited or not. Try going to the xref you are trying to change and checking this option.
