OldRed Posted May 14, 2013 Posted May 14, 2013 I've searched the forums and see plenty of discussion about sectioning but nothing that describes what I've used. The last place I Detailed, using MEP, they had a command, "sect" that would prompt for a front of view point, then a rear of view point (usually ortho but not necessarily) for depth of field. We would just click on the drawing rather than draw lines. It would then turn the current viewport into that section view. Anyone familiar with this? The camera function seems closest to this but not nearly as concise. Quote
SLW210 Posted May 14, 2013 Posted May 14, 2013 Is this plain vanilla AutoCAD? SECTIONPLANE and SECTION might be what you want. Quote
OldRed Posted May 14, 2013 Author Posted May 14, 2013 AutoCAD MEP. I looked at those & it appears they are more for creating sections of objects. The "sect" command we used was like changing the view to front or side but with a depth of view. Quote
SLW210 Posted May 14, 2013 Posted May 14, 2013 You posted in the AutoCAD 3D Modelling & Rendering forum, I'll move your post to the MEP forum. Quote
Marvin7 Posted May 14, 2013 Posted May 14, 2013 I don't know MEP. Model Documentation/Drawing Views can be used for sectioning, and from what I've tried it looks promising enough, so you can look into that. But that method was only introduced in 2012 I think and it only gained section and enlarged details abilities in 2013, so not many people have gotten into it yet. You can see a post I made recently on it (though there are no replies yet). http://www.cadtutor.net/forum/showthread.php?79205-Drawing-Views-Model-Documentation-detail-of-projected-view-bug Quote
