How To Adjust Viewres in 3ds Max?
How do I adjust the viewres in the 3ds Max?
Thank you
There is no "viewres" in Studio Max. That is an Autocad term. What exactly is the problem?
This is the best tool ever!!!
And I believe it is what OP is looking for..
See when you are modeling stuff like characters or blueprints the viewport preview may make the image blurry.
You can run these max scripts to increase the view resolution
NitrousGraphicsManager.SetTextureSizeLimit 2048 true
NitrousGraphicsManager.SetBackgroundTextureSizeLimit 2048 true
or you can use this tool...
This tool fixes it!!
The problem with this tool is that you probably wont be able to install it because you simply don't know how
It's fairly easy to install
just drag it into max and it will be installed
you can then find it under
Customize user interface
Toolbars
--->>>> Category >>>> Spacefrog tools
you can drag it out from here to a max toolbar
