Ramana Posted November 18, 2008 Posted November 18, 2008 Hello Friends, Greetings, through lisp how to find the number of objects of a BLOCK and how to change its general properties. for example:- I have few circles in a block, which i would like to change its color, and few other objects thinckness. thanks & Regards Ramana Quote
ReMark Posted November 18, 2008 Posted November 18, 2008 What version are you currently using? There should be a block counter in Express Tools called, strangely enough, BCount. It's a lisp program. Quote
ASMI Posted November 18, 2008 Posted November 18, 2008 Short example in Visual LISP Console window: Load Visual LISP extension: _$(vl-load-com) Get object of an Active Document: _$ (setq actDoc(vla-get-ActiveDocument(vlax-get-acad-object))) #<VLA-OBJECT IAcadDocument 01ff6950> Get Blocks Collection: _$ (setq blCol(vla-get-Blocks actDoc)) #<VLA-OBJECT IAcadBlocks 0e57d01c> Get object of block with name "block1": _$ (setq cBl(vla-Item blCol "block1")) #<VLA-OBJECT IAcadBlock2 0e57d47c> Retrieve number of entities of block: _$ (vla-get-Count cBl) 4 Paint all circles in Red color (1): _$ (vlax-for e cBl (if(= "AcDbCircle"(vla-get-ObjectName e))(vla-put-Color e 1))) nil Regenerate document to see change of color in block references: _$ (vla-regen actDoc 1) Regenerating model. Quote
Ramana Posted November 19, 2008 Author Posted November 19, 2008 thanks friends, I have not checked in express tools, I will go through it. thanks again for vlisp codes. Ramana Quote
