JADT Posted August 27, 2013 Author Posted August 27, 2013 Hi All, thanks for the thread hi-jack... My problem has not been resolved but glad others have. I understand everyone here is helping each other out for free and out of the goodness of their hearts, so If there is any of that coding love left over, could someone please help out with my issues in the original thread. just to recap: pBe's code did just what I needed...but when adding new layouts to a project and re-running the lisp it added a (1) suffix to all the existing layouts - a failsafe that pBe put in to avoid any issues with layouts having the same name...I would prefer for the code to ignore renaming layouts if they haven't changed in the tags they are reading or at least to not suffix with (1). I hope someone can help with this and thanks once again for everyone's time..i'm only on the 'hello world' stage of learning code. Quote
Lee Mac Posted August 27, 2013 Posted August 27, 2013 Here is a quick modification of my code from Reply#15: ([color=BLUE]defun[/color] c:relay ( [color=BLUE]/[/color] a e i l n r s x ) ([color=BLUE]if[/color] ([color=BLUE]setq[/color] s ([color=BLUE]ssget[/color] [color=MAROON]"_X"[/color] '((0 . [color=MAROON]"INSERT"[/color]) (66 . 1) (2 . [color=MAROON]"A1 Border"[/color]) (410 . [color=MAROON]"~Model"[/color])))) ([color=BLUE]progn[/color] ([color=BLUE]repeat[/color] ([color=BLUE]setq[/color] i ([color=BLUE]sslength[/color] s)) ([color=BLUE]setq[/color] e ([color=BLUE]entnext[/color] ([color=BLUE]ssname[/color] s ([color=BLUE]setq[/color] i ([color=BLUE]1-[/color] i)))) x ([color=BLUE]entget[/color] e) a [color=BLUE]nil[/color] ) ([color=BLUE]while[/color] ([color=BLUE]=[/color] [color=MAROON]"ATTRIB"[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 0 x))) ([color=BLUE]setq[/color] a ([color=BLUE]cons[/color] ([color=BLUE]cons[/color] ([color=BLUE]strcase[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 2 x))) ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 1 x))) a) e ([color=BLUE]entnext[/color] e) x ([color=BLUE]entget[/color] e) ) ) ([color=BLUE]setq[/color] l ([color=BLUE]cons[/color] ([color=BLUE]cons[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 410 ([color=BLUE]entget[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 330 x))))) a) l)) ) ([color=BLUE]vlax-for[/color] x ([color=BLUE]vla-get-layouts[/color] ([color=BLUE]vla-get-activedocument[/color] ([color=BLUE]vlax-get-acad-object[/color]))) ([color=BLUE]if[/color] ([color=BLUE]and[/color] ([color=BLUE]setq[/color] a ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] ([color=BLUE]vla-get-name[/color] x) l))) ([color=BLUE]setq[/color] n ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] [color=MAROON]"DRAWINGNO."[/color] a))) ([color=BLUE]setq[/color] r ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] [color=MAROON]"REV"[/color] a))) ) ([color=BLUE]vl-catch-all-apply[/color] '[color=BLUE]vla-put-name[/color] ([color=BLUE]list[/color] x ([color=BLUE]strcat[/color] n [color=MAROON]"_"[/color] r))) ) ) ) ([color=BLUE]princ[/color] [color=MAROON]"\nNo \"A1 Border\" blocks found."[/color]) ) ([color=BLUE]princ[/color]) ) ([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color]) The above program is untested however. Quote
JADT Posted August 27, 2013 Author Posted August 27, 2013 Lee, thanks for your speedy reply. on first test it seems to work. That's really helped. Thank you. Just realised though, on the project I have just tested, we have various sized drawings some A3 as such they didn't rename. Would it be possible to add into the code to search on all the company standard size border blocks that 'may' be in use in a project. they are A0 Border A1 Border A2 Border A3 Border Quote
Lee Mac Posted August 27, 2013 Posted August 27, 2013 Lee,thanks for your speedy reply. on first test it seems to work. That's really helped. Thank you. You're welcome Would it be possible to add into the code to search on all the company standard size border blocks that 'may' be in use in a project.they are A0 Border A1 Border A2 Border A3 Border Change: (2 . [color=MAROON]"A1 Border"[/color]) to: (2 . [color=MAROON]"A[0-3] Border"[/color]) Quote
JADT Posted August 27, 2013 Author Posted August 27, 2013 i'll have a go with that. Thanks again Quote
JADT Posted August 29, 2013 Author Posted August 29, 2013 Lee, thanks for your help. All seems to work perfectly. Quote
asos2000 Posted October 31, 2013 Posted October 31, 2013 Try this quick code:... I am tring to modfy this lisp to mach my needs How to grab attribute tag? (defun c:relay ( / a blk e i l n r s tg x ) ;; Author: Lee Mac, www.lee-mac.com (setq *blknm "*-A[0-3]-TB") ; Title Block (setq *tg "A000") ; Drawing Number TAG in title block (if (not *ans) (setq *ans "RenameLayout")) ;check for editing setting or not (initget "RenameLayout Setting") (setq *ans (cond ( (getkword (strcat "\n Title Block Name: " *blknm " ,Drawing Number TAG: " *tg " Choose [RenameLayout/Setting] <" *ans ">: ")))( *ans ))) (if (> 8 (strlen *ans)) ;editing setting or not (progn (setq blk (entget (car (entsel "Select Drawing Number in Title Block: ")))) (setq *blknm (cdr (assoc 2 blk))) [color="red"] (setq *tg *tg) <--- How to grab attribute tag [/color] )) (if (setq s (ssget "_X" (list '(0 . "INSERT") '(66 . 1) (cons 2 *blknm) '(410 . "~Model")))) (progn (repeat (setq i (sslength s)) (setq e (entnext (ssname s (setq i (1- i))))) (setq x (entget e)) (setq a nil) ) (while (= "ATTRIB" (cdr (assoc 0 x))) (setq a (cons (cons (strcase (cdr (assoc 2 x))) (cdr (assoc 1 x))) a) e (entnext e) x (entget e) ) ) (setq l (cons (cons (cdr (assoc 410 (entget (cdr (assoc 330 x))))) a) l)) ) (vlax-for x (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object))) (if (and (setq a (cdr (assoc (vla-get-name x) l))) (setq n (cdr (assoc *tg a))) ) (vl-catch-all-apply 'vla-put-name (list x n )) ) ) ) (princ "\nNo title block found.") ) (princ) ) (vl-load-com) (princ) Quote
Lee Mac Posted October 31, 2013 Posted October 31, 2013 I am tring to modfy this lisp to mach my needs How to grab attribute tag? I would suggest the following Hasan: ([color=BLUE]defun[/color] c:relay ( [color=BLUE]/[/color] *ans* a att blk e enx i l n s tag tmp x ) [color=GREEN];; Author: Lee Mac, www.lee-mac.com[/color] ([color=BLUE]setq[/color] blk [color=MAROON]"*-A[0-3]-TB"[/color] [color=GREEN];; Block[/color] tag [color=MAROON]"A000"[/color] [color=GREEN];; Tag[/color] ) ([color=BLUE]if[/color] ([color=BLUE]null[/color] *ans*) ([color=BLUE]setq[/color] *ans* [color=MAROON]"Rename"[/color]) ) ([color=BLUE]while[/color] ([color=BLUE]progn[/color] ([color=BLUE]initget[/color] [color=MAROON]"Rename Settings"[/color]) ([color=BLUE]if[/color] ([color=BLUE]setq[/color] tmp ([color=BLUE]getkword[/color] ([color=BLUE]strcat[/color] [color=MAROON]"\nBlock: \""[/color] blk [color=MAROON]"\", Tag: \""[/color] tag [color=MAROON]"\" [Rename/Settings] <"[/color] *ans* [color=MAROON]">: "[/color]))) ([color=BLUE]setq[/color] *ans* tmp) ([color=BLUE]setq[/color] tmp *ans*) ) ([color=BLUE]/=[/color] [color=MAROON]"Rename"[/color] tmp) ) ([color=BLUE]while[/color] ([color=BLUE]progn[/color] ([color=BLUE]setvar[/color] 'errno 0) ([color=BLUE]setq[/color] att ([color=BLUE]car[/color] ([color=BLUE]nentsel[/color] [color=MAROON]"\nSelect drawing number <back>: "[/color]))) ([color=BLUE]cond[/color] ( ([color=BLUE]=[/color] 7 ([color=BLUE]getvar[/color] 'errno)) ([color=BLUE]princ[/color] [color=MAROON]"\nMissed, try again."[/color]) ) ( ([color=BLUE]null[/color] att) [color=BLUE]nil[/color]) ( ([color=BLUE]/=[/color] [color=MAROON]"ATTRIB"[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 0 ([color=BLUE]setq[/color] enx ([color=BLUE]entget[/color] att))))) ([color=BLUE]princ[/color] [color=MAROON]"\nPlease select drawing number attribute."[/color]) ) ( ([color=BLUE]setq[/color] tag ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 2 enx)) blk ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 2 ([color=BLUE]entget[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 330 enx))))) ) [color=BLUE]nil[/color] ) ) ) ) ) ([color=BLUE]if[/color] ([color=BLUE]setq[/color] s ([color=BLUE]ssget[/color] [color=MAROON]"_X"[/color] ([color=BLUE]list[/color] '(0 . [color=MAROON]"INSERT"[/color]) '(66 . 1) ([color=BLUE]cons[/color] 2 blk) '(410 . [color=MAROON]"~Model"[/color])))) ([color=BLUE]progn[/color] ([color=BLUE]repeat[/color] ([color=BLUE]setq[/color] i ([color=BLUE]sslength[/color] s)) ([color=BLUE]setq[/color] e ([color=BLUE]entnext[/color] ([color=BLUE]ssname[/color] s ([color=BLUE]setq[/color] i ([color=BLUE]1-[/color] i)))) x ([color=BLUE]entget[/color] e) a [color=BLUE]nil[/color] ) ([color=BLUE]while[/color] ([color=BLUE]=[/color] [color=MAROON]"ATTRIB"[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 0 x))) ([color=BLUE]setq[/color] a ([color=BLUE]cons[/color] ([color=BLUE]cons[/color] ([color=BLUE]strcase[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 2 x))) ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 1 x))) a) e ([color=BLUE]entnext[/color] e) x ([color=BLUE]entget[/color] e) ) ) ([color=BLUE]setq[/color] l ([color=BLUE]cons[/color] ([color=BLUE]cons[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 410 ([color=BLUE]entget[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 330 x))))) a) l)) ) ([color=BLUE]vlax-for[/color] x ([color=BLUE]vla-get-layouts[/color] ([color=BLUE]vla-get-activedocument[/color] ([color=BLUE]vlax-get-acad-object[/color]))) ([color=BLUE]if[/color] ([color=BLUE]and[/color] ([color=BLUE]setq[/color] a ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] ([color=BLUE]vla-get-name[/color] x) l))) ([color=BLUE]setq[/color] n ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] tag a))) ) ([color=BLUE]vl-catch-all-apply[/color] '[color=BLUE]vla-put-name[/color] ([color=BLUE]list[/color] x n)) ) ) ) ([color=BLUE]princ[/color] [color=MAROON]"\nNo title block found."[/color]) ) ([color=BLUE]princ[/color]) ) ([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color]) Quote
asos2000 Posted October 31, 2013 Posted October 31, 2013 (edited) Brilliant as usual What about replace (setq blk "*-A[0-3]-TB") With (if (setq ss (ssget "_X" (list '(0 . "INSERT") '(66 . 1) (cons 2 "*TB") '(410 . "~Model")))) (setq blk (cdr (assoc 2 (entget (ssname ss 0))))) (setq blk "\nNo title block found.")) Edit: Instead of grabing tag, could the prompt be grabed? I used (setq enx (entget att)) but couldnet find DXF for prompt Edited October 31, 2013 by asos2000 Quote
pBe Posted October 31, 2013 Posted October 31, 2013 Hi All,pBe's code did just what I needed...but when adding new layouts to a project and re-running the lisp it added a (1) suffix to all the existing layouts - a failsafe that pBe put in to avoid any issues with layouts having the same name. It would be easy to modify the code to meet your conditions but I see you already have a solution from Lee. (kudos to LM) Quote
